Old 02-28-2023, 01:20 PM #1
Stewmatic508 Stewmatic508 is offline
Stewmatic508 is on a distinguished road
Exclamation p0305 code
Okay thanks if you are reading this.
2010 4Runner, 4.0 v6 232,000 miles
I thought I had a transmission issue. I kept getting what felt like slipping when shifting from 3 to 4 or 2 to 3. After a while I had a issue come up where it turned out i had some misfiring going on. Cylinders 1 3 and 5 with check engine light on and running very rough.
I had the spark plugs and coils changed and it ran fine again. Now i am getting cylinder 5 codes that come up every once in a while. If the code comes up and i am getting misfired I unplug the coil and fuel injectors reset the code and it comes back to life.
Today however I reset the code and it seems to be more persistent, I have tried multiple coils. Not sure what to do at this point. Looking for help! not sure what else to do at this point. I was told by one mechanic it could be the timing chain.
2010 4Runner Limited V6
Stewmatic508 is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 04:48 PM #2
Mestalbaum Mestalbaum is offline
Mestalbaum is on a distinguished road
sensors, timing or all of the above
Hey stewmatic508,
I just joined to hopefully find some answers and your post was the closest thing to my issue. I have a 2011 SR5 4.0L V6 with 214,000 miles. Noticed a little lag in power so went to change my plugs. Plug on my 4th cyl had oil in it. Changed my valve cover gasket got everything hooked back up. Started up and was running fine but my Check engine light (CEL) came on along with my Traction control light. So I pulled the codes and it was for my cam shaft position sensors a & b (bank 2) and my Mass air flow sensor. I ordered the OEM sensors and replaced them, cleared the codes but the CEL came back on with the traction control light. Took it to my local shop and they diagnosed for about 3 hours and the only thing they came back with as a possibility was the VVT solenoids. So i ordered the OEM solenoids and replaced them. Used my scan tool and cleared the codes. Started it up and CEL and traction light still come on. The shop is telling me the only other thing it could be is the timing chain. Im wondering if you ever found a solution to your issue and what it ended up being.
Thanks,
Mike
Mestalbaum is offline   Reply With QuoteReply With Quote
code , coils , issue , point , reset
p0305 code Stewmatic508 5th gen T4Rs 5 02-28-2023 07:30 PM
P0305 Question Herbie 3rd gen T4Rs 2 01-17-2022 08:49 PM
P0305 code....ugg! Need help! Border411 4th Gen T4Rs 51 01-02-2016 11:57 PM
2005 V8 - CEL P0305 Help Please Volley 4th Gen T4Rs 5 09-02-2015 11:42 AM
P0305 Code & That's the Good News! (Still not fixed though) BrianSD_42 3rd gen T4Rs 13 08-10-2014 09:38 PM
