Old 03-12-2023, 09:02 PM #16
Low&Slow Low&Slow is offline
Low&Slow is on a distinguished road
Originally Posted by Bmnorm2 View Post
Seems like this cleaning and lubing procedure should be added to the PM schedule. At least for the DIYers. What grease did you use? Your instructions imply you didn’t actually remove it from the transmission?
Where I live we use salt on the roads for 5 months of the year so it’s now part of my routine but probably not necessary for folks living down south. I used Lucas red n tacky, it was what I had on hand at the time. No, I didn’t remove it. Cycling it back and forth with penetrating oil before I greased it seemed to do the trick.
Cheers!
Low&Slow is offline   Reply With QuoteReply With Quote
Old 03-13-2023, 01:28 PM #17
GaryL GaryL is offline
GaryL is on a distinguished road
I got my repaired 4R back, all is good now. I did get the old NSS switch back and did some investigating, opened the body to see where the binding or water intrusion was coming from.
If I can I will show pictures of a new switch and my old one. My findings are interesting. There was no moisture inside the electrical contacts at all and no binding while the switch is out of the tranny post. For sure, all of the binding was happening where the locking nut holds the switch to the tranny post. That portion on my old switch was broken off in the removal process. As I said, there was nothing wrong with the switch internally that would cause this malfunction. The binding was occuring at the connection point locking nut with a spring type washer. I would think keeping that post lubricated as a normal maintenance item could avoid future issues. The electrical connector did not have any corrosion and appears to be clean and dry so my plan is to slather the external locking nut and washer with white lithium grease when I do the oil and filter changes.
I am unable to show my old switch because the attachment fails, probably too large and I have no idea how to resize it to fit here.
Stiff shifter 2016 4R limited-48f37da7e661efaebb5a3f953fb83dda-jpg  Stiff shifter 2016 4R limited-img_2907-jpg
GaryL is offline   Reply With QuoteReply With Quote
dash , display , engine , guide , shifter
2010 4Runner - Stiff shifter - No D light Stewart 5th gen T4Rs 15 11-13-2023 11:42 AM
Relocating 4X4 switch on Limited TCASE Shifter shadow247 3rd gen T4Rs 4 11-28-2020 12:38 PM
Limited wood dash/shifter swap Jemplyr77 5th gen T4Rs 7 05-22-2019 09:08 AM
Rattle noise at tranny shifter - 1999 Limited 67siia 3rd gen T4Rs 8 08-03-2011 06:23 PM
