Old 03-09-2023, 09:38 PM #1
Thanh Thanh is offline
Thanh is on a distinguished road
suspension control arm ball joint gone bad
hello guys
when i replacing suspension for my 2016 4runner sr5, i found out that my suspension control arm ball joint got crack so i went online and looking for the ball joint but i couldn't find it anywhere. I don't want to buy the whole suspension control arm left and right which is cost 600$ for a pair just for the balls joint fix.
Could you guys help me looking for me the part numbers for the lower control arm ball joints left and right, please.
Thank you very much for your consideration
Danny
Thanh is offline   Reply With QuoteReply With Quote
Old 03-09-2023, 09:42 PM #2
Jeremy556's Avatar
Jeremy556's Avatar
They are only sold as the control arm, complete.
Old 03-09-2023, 11:13 PM #3
Forgetful Forgetful is offline
Forgetful will become famous soon enough Forgetful will become famous soon enough
Look on the bright side, you get new bushings too which if you off-road get beat up more. Might as well do the other side while you're at it....
Or visit a pick and pull to get one. I saw some on eBay too
Forgetful is offline   Reply With QuoteReply With Quote
Old 03-10-2023, 09:32 AM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I bought a used one couple years ago and it was fine. Also, 1Aauto sells new aftermarket which are pretty good quality for about $200 each, I'm running them on mine.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 03-10-2023, 04:44 PM #5
djeepin djeepin is offline
djeepin is on a distinguished road
What do you mean get crack? Rubber boot? If metal get crack, it will fall off, snap in half. If rubber boot cracked due to old age, so replace a boot if you cought it early. Febest in FL makes all boots, and it is good practice to replace them before they become brittle, about 7 years. Replace them all, upper and lower. And internal axle boot too.
djeepin is offline   Reply With QuoteReply With Quote
arm , ball , control , joint , suspension
Disassemble SPC control arm ball joint to remove coilover? joshoowa 5th gen T4Rs 2 04-10-2021 02:01 PM
Upper ball joint and Control Arm Seized Brveagle 3rd gen T4Rs 4 10-05-2016 04:41 PM
Lower Control Arm Failure (ball joint seems intact) parnavaz 3rd gen T4Rs 21 08-07-2016 08:48 PM
Dirty control arm - lower ball joint? _Aaron_ 3rd gen T4Rs 9 02-16-2014 01:25 AM
