Old 03-12-2023, 09:24 AM #1
blackie2's Avatar
blackie2 blackie2 is offline
blackie2 is on a distinguished road
blackie2's Avatar
Oil Filter Drain Gasket Failure
This little gasket failed and created quite a mess in my garage. Never had one break like this. Changed my oil on Friday and yesterday I had oil all over the skid plates and front differential. Luckily I had a spare in my tool box and all is good now. I used an OEM oil filter for the change.
Oil Filter Drain Gasket Failure-pxl_20230312_131925289-jpg
2021 SR5 Premium 4x4 stock, Nitto Terra Grapplers
blackie2 is offline   Reply With QuoteReply With Quote
Old 03-12-2023, 12:14 PM #2
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Looking at the bottom right of the big section near the tear it looks like it may have been pinched. It’s possible it wasn’t settled in the groove when you installed the drain cap.
What did you torque the drain plug to? Spec is 10 ft-lbs.
Or it was a bad o-ring, but statistics say human error is significantly more likely… shit happens.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 03-12-2023, 04:27 PM #3
blackie2's Avatar
blackie2's Avatar
I have no idea on the torque. I just tightened it up snug and left it.
Old 03-12-2023, 05:19 PM #4
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
It looks to me like it was probably not seated properly, and the bit that's missing from the O-ring was pinched between the drain plug and housing, when the drain plug was tightened.
As previously mentioned.
02SE is offline   Reply With QuoteReply With Quote
Old 03-12-2023, 06:53 PM #5
djeepin djeepin is offline
djeepin is on a distinguished road
even this aluminum drain cap wasn't installed, oil should not leak, as the valve inside filter housing, need to be open. something wrong here.
djeepin is offline   Reply With QuoteReply With Quote
Old 03-13-2023, 06:58 AM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Easy to pinch those, have to work the drain cap back and forth a few times until it finds its home in the groove before torquing to 10ft
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
filter , gasket , luckily , oil , skid
Prevalence of V6 Head Gasket Failure? rwh963 4th Gen T4Rs 5 11-24-2020 09:35 AM
Preventing head gasket failure in 04 V6 evan1242 4th Gen T4Rs 8 12-17-2019 09:36 PM
Borescope pics. Head gasket failure? thewaydown 4th Gen T4Rs 18 03-30-2019 01:32 PM
Head gasket failure on the V8? bergs 4th Gen T4Rs 27 11-08-2018 11:12 PM
Thermostat gasket failure? DK327 3rd gen T4Rs 5 06-11-2018 12:57 PM
