Old 03-12-2023, 08:12 PM #1
BlueRunner428 BlueRunner428 is offline
BlueRunner428 is on a distinguished road
Can Jump Starting Another Vehicle Damage the 4Runner?
So my father's battery in his Suburban died, so I figured I would use my 4Runner and jump it. However then when my mother found out, she freaked and said do NOT do that, it can mess up the electronics and computers in the newer vehicles. After some Googling, I have found she is correct. Also I didn't use the proper technique I discovered, I hooked up the positive and negative on the 4Runner, then the negative to the engine block and the positive to the battery in the Suburban. I read though that you should always hook up both positives first. Did I run a serious risk of damaging my vehicle's electronics?
BlueRunner428 is offline   Reply With QuoteReply With Quote
Old 03-12-2023, 08:40 PM #2
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
If you're an idiot, then possibly.
Sent from my SM-G996U using Tapatalk
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
Old 03-12-2023, 08:46 PM #3
Jeremy556's Avatar
Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold
Jeremy556's Avatar
Unless its got a short or you hookup cables backwards, it'll be just fine. The little lithium jump starter packs are way more versatile, can be used to self jump, and wouldn't be a big deal if it shorted out on something.
Old 03-12-2023, 08:49 PM #4
rochmpr's Avatar
Real Name: Krister
rochmpr's Avatar
Real Name: Krister
Why to say it more politely Can Jump Starting Another Vehicle Damage the 4Runner?
Old 03-12-2023, 09:18 PM #5
How do I know if I was an idiot or not?
Old 03-12-2023, 09:21 PM #6
I didn't hook up the cables backwards, but how do I know if there was a short?
Old 03-12-2023, 09:41 PM #7
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is a jewel in the rough rigtec is a jewel in the rough rigtec is a jewel in the rough rigtec is a jewel in the rough
rigtec's Avatar
Real Name: Greg
If there was a short-circuit, you would know it by the instrument-cluster indicator lights! And if you connected the jumper-cables BACKWARDS ...you would've popped the Main 140A Alternator fuse [Real Trouble]; "you're fine!!"
~rig~
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 03-12-2023, 09:50 PM #8
Originally Posted by rigtec View Post
If there was a short-circuit, you would know it by the instrument-cluster indicator lights! And if you connected the jumper-cables BACKWARDS ...you would've popped the Main 140A Alternator fuse [Real Trouble]!!
~rig~
Well nothing came up on the instrument cluster and everything seems to be working correctly.
Old 03-12-2023, 09:58 PM #9
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Then, you're Good! BTW: I have jumped other trucks Lot-0-Times!
~rig~ Best!
Old 03-14-2023, 12:16 AM #10
Lexington's Avatar
Lexington Lexington is offline
Lexington has a spectacular aura about Lexington has a spectacular aura about Lexington has a spectacular aura about
Lexington's Avatar
I carry this Auden 20,000mAh jump starter in my 4Runner. It has served me very well. The only flaw is the “Boost” button is very small and is almost invisible. I also find frequently I have to use the boots to jumps start a car. I guess it depends on how far down the battery has been drained. Audew Car Jump Starter Battery Pack 20000 MAh
Lexington is offline   Reply With QuoteReply With Quote
Old 03-14-2023, 05:05 AM #11
Thanks; I've read though with these newer 4Runners that have the push button start and extra electronics that you have to be very careful jumping them, with either another vehicle or a jump starter.
Old 03-14-2023, 12:36 PM #12
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Over on the RAV4 forum, there are many reports of the hybrid ECU being damaged due to not connecting the jumper cables right.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-14-2023, 07:35 PM #13
Lexington's Avatar
Lexington's Avatar
I find that disappointing coming from Toyota. It’s bad enough that push button start vehicles are so easy to steal. This is another reason not to buy one.
Old 03-15-2023, 10:41 AM #14
Didn't know myself that they are easy to steal. I don't know if the increased sensitivity is something that is Toyota's fault though. It is just when you add more and more electronics and computers and things like push button start to vehicles, it means more things that could get fried by an electrical hiccup. But for the safety features and economy requirements, modern vehicles have to have such.
Old 03-15-2023, 11:20 AM #15
Lexington's Avatar
Lexington's Avatar
It’s completely Toyota’s fault! If the technology is that sensitive then it’s not ready for the market. Jump starting a car with a dead battery is a long time practice. Any car maker that introduces new technology must take this into consideration. If they don’t then they are doing a disservice to their customer.
4runner , electronics , found , jump , vehicles
Help with damage estimate and vehicle value 2runner4life 3rd gen T4Rs 8 03-01-2022 01:42 PM
Vibrations when starting vehicle? T4R03 4th Gen T4Rs 4 09-10-2019 01:54 PM
Engine dies after jump starting it qdizzzla General Discussions 10 01-24-2018 11:33 PM
Starting gets clicks jump start ok zorgon Classic T4Rs 1 11-16-2011 10:59 PM
EL003-04 03/03/2004 Electrical - 'Crank Hold System' Jump Starting CBR_GUY_IA TSB 0 07-12-2009 10:35 PM
