03-17-2023, 09:45 AM
In town gas mileage seems exceptionally poor
We have a '22 ORP with around 8K miles on it. Freeway mileage seems around 17s on average (think I got 19 once). But I drive mostly city, stop and go traffic, short trips. I recently checked the mileage and read just in the 11s. I don't drive hard, no Jackrabbit starts, speeding or other aggressive habits, I try to drive as smoothly as possible. Seems like I should be getting a little better than 11 MPG for all in-town driving!
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
03-17-2023, 09:53 AM
Can't really tell you what's wrong, but you should be doing better than that. I'm on 285s and average 15.5 with a 70/30 town/highway split. I work from home, so couple mile trips into town with the kids, running errands, etc. is what gets the majority of work for my 4R. Usually the highway drives are no more than 5-10 miles. The couple longer highway tanks I've calculated by hand are about 18-19 mpg with these tires depending on if I go north or west to the hills or south the the flats. I've lost about 2mpg overall with my current setup. I drive like a grandma as well.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
03-17-2023, 09:57 AM
Real Name: Neal
Real Name: Neal
Have you changed wheels and tires?
Basically Stock 2023 trd orp - I have about 3000 miles on the ODO, I'm getting over 20mpg on the highway, about 16-17mpg in town.
Beats the hell out of my lightly modded (tires/winch/lift, etc) 2011 TE, It's at 120k on the ODO, but barely averages 16mpg. I get about 14 in town....
03-17-2023, 10:41 AM
Everything is stock, with the Bridgestone All Season "street" tires.
Is it possible the computer is reading it wrong? I know my radio will no longer let me save any presets for some reason.
03-17-2023, 10:54 AM
Same opinion here. I'm at 12 city, 13 mixed, 15-16 highway with 33's, 2.5" lift, ALL the armor, Tacobox crawlbox and a roof rack full of gear.
Probably at least 500-750lbs over stock.
I do take advantage of cruise control when i'm going faster than 40-50 on the highway, and I keep my speeds under 65 pretty religiously. Also, I keep my tires well-inflated.
I usually have a range of about 350miles. Then again - I have to put this out there - I don't care? I didn't buy this truck for the fuel mileage, we bought it for the capability/durability/reliability, I'd much rather have an engine known to go 100-200k miles with zero issues than one that gets 20-25 mpgs but also has known faults (our 2.7 Ecoboost, in our F150, for example - we're babying it, driving it lightly and are pretty much ready to chuck it at/before 100k)
some thoughts:
Maybe a brake caliper(or calipers) is/are dragging?
Maybe a bearing is bad, causing resistance?
Tire inflation?
Reset trip meter at each tank to get a new reading?
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
03-17-2023, 10:56 AM
Think I'll take it in and ask them WTH is going on.
03-17-2023, 11:05 AM
Real Name: Neal
Real Name: Neal
I always track the mpg separately with a phone app. Not that the built in computer is wrong, it's not to much different. Try tracking it separately for awhile and see what you get before spending $$$ at the dealership.
03-17-2023, 11:32 AM
Screw the ecoboosts. 5.0L is where it's at for those and probably the only Ford truck engine I'd consider buying outside of maybe the 7.3L. Same reasoning. Sacrifice some MPG for reliability, but also way more power. 5.0L are great engines.
that's what I'd do, too, since it's most likely still under warranty? Could be user error , but more than likely it's probably a small issue like the computer needing to be re-flashed or a bearing/brake issue.
If it's a bigger issue like the 4WD system, that'd be great to get sorted, but I doubt that's the issue, if you don't have any other idiot lights going off or any other symptoms.
03-17-2023, 01:31 PM
i see the op is in San Francisco. Every time I have been there it has been bumper to bumper traffic and many steep roads. 11 may be all you are going to get.
03-17-2023, 02:38 PM
San Fran is one of the worst places for mileage you're going to encounter. Take it out on an open road and set cruise at 60mph for a few miles and see. When I lived in mid town Atlanta, I was getting around 10mpg when stock. Short trips (rich warm up) and sitting in traffic not moving kill your MPGs when you're doing short distances overall.
03-17-2023, 02:53 PM
Yes, S.F. has some gnarly steep hills, but my 6 mile round trip is fairly flat. I think I used to get between 15 and 16 but hadn't checked in a while. We got between 17 and 18 on highway when we did a long road trip last summer, so I know it's capable. Maybe the dealer can find something our of whack when the plug in the computer.
03-17-2023, 02:55 PM
Driving has stayed the same, on average, but mileage used to be better. I looked at the History section of the Eco tab in the vehicle history and this is an all time low.
03-17-2023, 03:18 PM
Real Name: Howard J. Turkstra
Do they have winter fuel blends in CA?
In Chicago, I get worse mileage in the winter than in the summer because of the crappy winter gasoline here. (Longer warm up times, snow, etc., too.)
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
03-17-2023, 03:21 PM
CA does use a winter-blend fuel, as far as I know? Do they use it in the SF area?
it's widely believed to be a source of poorer mpg's during winter months for most vehicles. I think they roll it out around Oct each year.
