Old 09-10-2010, 07:01 PM #1
crenkas's Avatar
crenkas crenkas is offline
crenkas is on a distinguished road
crenkas's Avatar
Bilstein 5100 Height Settings
I've got a set of Bilstein 5100s waiting to be installed next week and I'm super torn between using setting 2 (0.85") or setting 3 (1.75"). I've searched all through the forums and a couple guys have used setting 3 and posted pics. They seem to think that it raises the front a touch too much relative to the rear. But no one has talked about setting 2. Has anyone used setting 2? Thoughts?? I'm throwing Nitto T/G 285s under at the same time, so looking for a little clearance to avoid rub.
Thx
Cam
crenkas is offline   Reply With QuoteReply With Quote
Old 09-10-2010, 10:27 PM #2
Als VARunner's Avatar
Als VARunner Als VARunner is offline
Als VARunner is on a distinguished road
Bilstein 5100
I am not sure if there is a difference between the TE versus the SR5 and Limited original heights. I used the 1.75 because the difference is a little over two inches from front to back on my TE. The back is still about 1/2 inch higher, but looks leveled. I did not want to spend the money for just a .85 lift.
2010 T4R Silver TE , KDSS, NAV, Spider Net, Cargo Net, Chrome Exhaust Tip, Front Bilstein 5100 (2.5"), Rear Daystar 1.5" (actual 1" lift), Dura Tracs 285/70/17, N-Fab Nerf Steps
Als VARunner is offline   Reply With QuoteReply With Quote
Old 09-11-2010, 09:48 AM #3
4RunnerTrail 4RunnerTrail is offline
4RunnerTrail is on a distinguished road
I too would like to add the Bilsteins. I'm thinking the 3rd raise. Did you have to realign your truck? did you notice any handling differences with raising front 2 inches? What are the negatives of raising the front. (curious as to why they did this from the factor with lower in the front)
I'd love to see more pics. I don't think i'm ready for a 3/2 lift and was thinking this may be the way to go. On the fence with upgrading too 285s... may keep stock size in new tread.
4RunnerTrail is offline   Reply With QuoteReply With Quote
Old 09-11-2010, 12:43 PM #4
crenkas's Avatar
crenkas's Avatar
Thanks for the reply. I think the stock height differences are the same as my sr5 is 2-1/4 front to back on the passenger side and 1-7/8 on the drivers side. I'm good with 1.75" lift on the front, but on the FJ forum regarding the 5100s posters were saying the were actually getting over 2" of lift. I think this was because the 5100s were actually 1/2" longer than the stock shock. Wondering if this is the case with the 4runner as well. Doesn't sound like it. Also, any comment on the handling once its been leveled? Does it get that light washy feel like when towing a heavy load?
I don't mind a little rake so still considering the second setting so long as it gives me clearance on my 285s. Anyone out there using setting two?
Thx
Cam
2010 4Runner | SR5 | Metallic Grey | 285-70/17 Nitto Terra Grapplers | Fuel Octane Wheels 17x8.5 | Bilstein 5100s (fronts at 1.75") | OME 885E Rear Springs | Husky Liners | Mangowalk 5" Antenna
Old 09-11-2010, 01:39 PM #5
Bilstein 1.75 level
The ride seems a little less loose in the front and because of the front level, the hard nose down during breaking is not as bad. This is because the momentum of the truck is now going more forward instead of down (direction of nose). Others in the forum might have had different results. I am very happy with the new ride and lift.
The shop that installed them said I needed an alignment.
I believe my 1.75 lift was really 1.75 since my rear is slightly higher than the front. I did not personally measure it, but the shop said it is very close. There is another notch to raise to either 2.25 or 2.5 (do not remember which it is), but then you would need to raise the back also so you do not have a negative rake with the front higher.
If you want to see more pictures, I have pics in the 5th gen picture thread on 9 August.
There are many other threads if you do a search on larger tires with lifts concerning the clearance. There are also other threads on the front rake and the bilstein 5100's if you do a search.
I have never changed a stock vehicle before, but the information I gained from this forum has given me the knowledge and confidence to know what to do.
Old 09-11-2010, 01:55 PM #6
crenkas's Avatar
crenkas's Avatar
We're in the same boat as I have never made any major changes to stock before either. I knew going into the 5th gen 4runner after my 4th gen that I wanted to beef it up a little. Not planning a major lift or much larger tires, but thought 285s in a more aggressive tread would be just right. These Bilsteins sound perfect for my need to get a little extra clearance in the front without spending too much or drastically changing the suspension. The added bonus is that they seem to improve the ride (especially nose dive). With all the great info and pics in these forums, not to mention willing guinea pigs , it makes it pretty easy to choose the right setup.
I will poke around a little more using the search function and see if I can get more info, but I've been pretty thorough so far (maybe even a little obsessed). Probably thinking way too much into the height adjustment, but it will need to be completely redone if I choose wrong and that will cost $$$.
Your ride looks great by the way. I will check out more of your pics.
Old 10-03-2010, 11:16 PM #7
Narkhelek's Avatar
Narkhelek Narkhelek is offline
Narkhelek is on a distinguished road
Narkhelek's Avatar
I'm thinking of getting a pair of front Bilstein 5100 to level out my TE and was wondering what's a reasonable amount to pay to have them installed. Don't want to get taken since I'm not sure what's involved in putting them in.
Narkhelek is offline   Reply With QuoteReply With Quote
Old 10-04-2010, 09:32 PM #8
I do not know if I got a good price, but the shop figured 3 hours labor, which was $225. Maybe someone else can tell you if I paid a good price or not.
Old 11-28-2010, 04:58 PM #9
westwind77's Avatar
westwind77 westwind77 is offline
westwind77 will become famous soon enough
westwind77's Avatar
Thinking of doing the 5100's as well, is the price above close to what others have paid? Well, I guess I should ask labor time since each shop charges different rates depending on where you are.
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
westwind77 is offline   Reply With QuoteReply With Quote
Old 11-28-2010, 05:45 PM #10
PracticalFJ PracticalFJ is offline
PracticalFJ is on a distinguished road
Does anyone know which model 5100's? Where is the best place and price for purchase?
Thanks
Jeffrey
10 Trail w/kdss, nav, and a really annoying hella horn
PracticalFJ is offline   Reply With QuoteReply With Quote
Old 12-03-2010, 07:00 PM #11
Will733's Avatar
Will733 Will733 is offline
Will733 is on a distinguished road
Will733's Avatar
Just installed
Finally got my 5100s put in today (Set at 1.75").
Total cost out the door was $330 after tax, installation, alignment, etc...
2010 MAGNETIC GRAY 4X4 SR5
Bilstein 5100's at 1.75" | Rear Driver Side Daystar 1.5" Spacer | 285/70/17 Duratracs | Spidertrax 1.25" Spacers | FJ Wheels | FJ Shift Knob | TE Grille
De-badged | Plasti Dipped Chrome | Pilot Stub Antenna | Shrockworks Sliders | Window Tint | Interior LED's | Air Dam Removed | Side Skirts Removed
Will733 is offline   Reply With QuoteReply With Quote
Old 12-03-2010, 08:06 PM #12
pmdata pmdata is offline
pmdata is an unknown quantity at this point
Very nice. Very nice.
2007 SR5 4Runner V6 4X4 - Nautical Blue
pmdata is offline   Reply With QuoteReply With Quote
Old 12-03-2010, 10:31 PM #13
2010riddle 2010riddle is offline
2010riddle is on a distinguished road
How's the handling/nose dive after these were installed? I know your running 275's, but do you think 285's would clear with the fender liner mod & this 3rd height setting? It sounds like the TE will clear but I think the sr5 has a bit less space under there.
BTW it looks great man. crazy how much better it looks with just 1.75" of lift. I see wheelers website & my CC meeting soon....
2010riddle is offline   Reply With QuoteReply With Quote
Old 12-04-2010, 04:17 PM #14
Will733's Avatar
Will733's Avatar
Thanks man, the handling and especially the nose dive has been much improved... Amazing how much better these are than stock. I'm running stock tire size (265's) but AT tires so their a bit more aggresive looking. Not sure how 285's would fit, sorry.
Old 12-19-2010, 08:56 PM #15
1traildriver's Avatar
1traildriver 1traildriver is offline
1traildriver is on a distinguished road
So was it exactly 1.75" of lift? I just got a set of 5100's and am gonna have the fronts installed this week (still waiting on the rears). Just wondering if the rumors filtering in from the FJ forum are true (about 2" of lift on the 3rd setting).
Thanks.
- "The Big Baller Toyota" 2010 TE, subdued badging, Satoshi grill mod, OW Lift, LR UCA's, KMC XD Enduro 17x9 wheels, 285/70-17 Kelly Safari TSR, Doug Thorley headers, Magnaflow cat-back, AFE CAI, URD MAF CAL, 4.56 gears, ARB front air locker, Wet Okole seat covers, M-PAC MOLLE panels, Hella Rallye 4000 compacts, Gobi Stealth with 40" single row LED combo light bar -
1traildriver is offline   Reply With QuoteReply With Quote
