Old 03-21-2023, 11:34 AM #1
FourRunner08 FourRunner08 is offline
FourRunner08 is on a distinguished road
2023 Wobble/Shimmy only when turning at speed
Hello friends!
I have a 2023 TRD OR with stock everything.
When driving 45+ MPH, and turning the wheel back and forth slightly (or just turning it and then it returning to center) the steering wheel shakes/shimmys as if it's wobbling. A good comparison is driving over rumble strips in the road. It only does it about 5 degrees to each side of center then it goes away. It does it both left and right. It's not particularly a vibration, it's more of a wobble/shake.
It does it 100% of the time. The dealership is clueless, they do feel it, but cannot just start replacing parts willy-nilly.
I've posted two videos to see if anyone sees anything of note.
Let me know your thoughts. It doesn't really shimmy/shake in a straight line. I really only see posts here about the 4runner shake, and this is a bit different.
Notes:
Wheels have been balanced twice and road force is less than 15
Truck has been aligned 3 times. Castor is at 3+
No rocks or malformation in tires. Have had a complete new set of tires no change
Video 1: Turning with a lot of bushing play. Normal? LCA Play Turning - YouTube
Video 2: Driving down road wiggling wheel. Notice anything that could cause vibration? 40 45 mph Video - YouTube
Thanks,
FourRunner08 is offline   Reply With QuoteReply With Quote
Old 03-21-2023, 11:58 AM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Originally Posted by FourRunner08 View Post
Hello friends!
Notes:
Thanks,
On the first video, yes, the inner bushing has lots of play (in and out, not up and down) in MY opinion. Not sure what is "normal", but, to me, that seems excessive.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-21-2023, 12:49 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a splendid one to behold rdruss is a splendid one to behold rdruss is a splendid one to behold rdruss is a splendid one to behold rdruss is a splendid one to behold rdruss is a splendid one to behold
rdruss's Avatar
Real Name: Ron
LCA bushings are rubber so there will be some "play". I assume that dealer checked torque on those LCA bolts, it is a high value as I recall. Other than that I assume you are at relatively low miles so wait it out and see if a warrantable problem develops.
If the problem gets worse with no obvious reason(s) then that's what a Toyota factory rep is for. Ask the dealer to contact their rep and report problem and next time he is at their dealer he can have your vehicle for his analysis.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 03-21-2023, 01:44 PM #4
Bobby12many's Avatar
Bobby12many Bobby12many is offline
Bobby12many will become famous soon enough
That LCA bushing definitely seems to be deforming way more than you would expect under those conditions (first vid)
The fact that you have had 3 separate alignments, which absolutely would/could involve adjusting front and rear camber plates on the LCA, makes me think something was not installed correctly, not torqued correctly, or the bushing was torn/damaged in a way to prevent secure fixation.
Bobby12many is offline   Reply With QuoteReply With Quote
Old 03-21-2023, 04:24 PM #5
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is a jewel in the rough rigtec is a jewel in the rough rigtec is a jewel in the rough rigtec is a jewel in the rough
rigtec's Avatar
Real Name: Greg
"ABSOLUTELY Bobby12many!!"
I watched the "Front LCA & Bushing move... 3/4s to an Inch (circularly), throughout the first video, ...view it Again! The bolts may be moving too... it has to be taken apart to assess the cause Fully!
~rig~
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
driving , road , tires , turning , wheel
Brief shimmy/sway/wobble when I press/let off accelerator rentarider 3rd gen T4Rs 22 10-12-2020 11:49 PM
front end wobble/shimmy! 01thunder 3rd gen T4Rs 12 10-06-2017 05:29 PM
High Speed Shimmy on 2015's ZJumper 5th gen T4Rs 26 03-14-2016 08:11 PM
Shimmy/wobble/shift when first pressing or first letting off gas. Link12 3rd gen T4Rs 5 01-09-2015 09:12 PM
high speed shimmy? morbidsanity 3rd gen T4Rs 17 02-25-2014 01:02 AM
