Old 03-22-2023, 05:16 PM #1
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
High Power Alternator install
Hello all....a couple weeks ago a thread was posted about stock electrical cap of the 4r.
Read here..
Stock electrical system excess capacity?
Anyways, long story short, Anthony with DC Power chimed in at some point and said that they produced a HP unit but some of the early units they sold encountered install issues with the 3rd party shops that were installing them. He asked if anyone was willing to give it a shot....I said yes for a couple reasons...always willing to help, and second I wanted to increase power for my winch and a planned odyssey battery. Full disclosure..Anthony did not ask me to post anything about this on the forum.
From my email to him after install last night.
I was able to install it last night. I think I recall you stating that the issue with the last person to try to install was something slightly off.
Because your design does not have the extra tab (see pic with old and new beside each other) I looked up the part number for a 19 vs 2020 (my truck) and they are the same. You also provided a bolt and nut because yours does not use the back tab with the captured nut. I suppose your billet is stronger than the casting of the OE one, so copying the OE design exactly is not required.
Anyways I proceeded with the install and noticed that there was a slight space between the top mounting bolt and the engine mount. The bottom bolts directly into a threaded hole in the engine head or block. What I did was run the bottom bolt all the way in, to the specified torque of 32 lbs. That left a .80 mm gap (measured with feeler gauge) between the upper tab (on the alternator) and the mounting tab on the engine. This may or may not be within tolerances, but I did not feel comfortable running it down as I did not want to tweek the billet front case. I did not have a super thin washer, so I placed a 1 mm copper crush washer in the space and torqued to 32 lbs with the included bolt and polylock nut. Everything looked straight and seems to be working fine. Visual observation of the new belt running at various rpms did not show misalignment or flexing of the unit. The before idle charging volts were at 13.59 all lights and accessories off...the after was 14.15V. I don't know for sure if this meets your expectations. I did not have a way to measure amp output...but as an anecdotal test, I tried to jump start my Land Cruiser LC100 which had a totally dead battery. A week or two ago it took my 4runner running at 2000rpm for several minutes to get the LC to turn over. This morning, the 4runner was able to start the LC running at idle with NO wait time.
Email end.
Other thoughts.
1. Getting the the stock alternator back bolt (not required on this unit) was not too bad if you know where to look.
2. I replaced the belt while in there with a new OE belt...should have done the idler pulleys too...but oh well.
3. The actual alternator is beautiful (if you are into that sort of thing like me)
4. I will go ahead a install an Odyssey battery now.
5. After the email, Anthony called me and asked for additional measurements which I will provide. He told me I could keep the alternator, which I fully expected to pay for...so that's awesome!
6. I feel good about the install and end result.
7. IMO the .80 mm gap could be a attributed the machining tolerances on the engine mounting point...if it is not on an exactly parallel plane as the other mounting point, this could throw it off slightly.
8. Did some research on DC power and they are certainly legit....youtube them for a factory tour.
Feedback or Questions welcome.
High Power Alternator install-20230322_115433-jpg  High Power Alternator install-20230322_153051-jpg  High Power Alternator install-20230322_153127-jpg  High Power Alternator install-20230322_153201-jpg  High Power Alternator install-20230322_153009-1-jpg  High Power Alternator install-20230322_153219-jpg
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 10:46 PM #2
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Originally Posted by lewdog998 View Post
"Hello all....a couple weeks ago a thread was posted about stock electrical cap of the 4r.
Read here..
Anyways, long story short, Anthony with DC Power chimed in at some point and said that they produced a HP unit but some of the early units they sold encountered install issues with the 3rd party shops that were installing them. He asked if anyone was willing to give it a shot....I said yes for a couple reasons...always willing to help, and second I wanted to increase power for my winch and a planned odyssey battery. Full disclosure..Anthony did not ask me to post anything about this on the forum..."
Hi lewdog998,
I have the very same set-up in my 2012 L.E. since about 2014; 270-XP and Odyssey 34R-1500T! The battery held up for 8 years; just replaced it in Feb of this year... GREAT Set-up! And my 270 tabs are the same e.g., bolt pattern, missing ears... But NEVER had a problem with belt alignment or any other mechanical/electronic anomalies!
~rig~ Enjoy!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 11:29 PM #3
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Ditto what @rigtec said above. I also have one in my 2011 TE. I got in on a great group buy!
I even did a write up on it here
Install was easy, and it fits perfect. No alignment issues and still running strong.
I just bought a 2nd 4runner ('23) and will be looking to upgrade that alternator as well. You can guess where I'll be buying it from.
nglayton is offline   Reply With QuoteReply With Quote
Old 03-23-2023, 03:26 AM #4
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Hey Neil,
Glad to hear your 270-XP is holding it down so well! I'm on my 2'nd T4R too; (3'rd GEN SR5), but stock alternator and battery! My next T4R [...I hope] is a 2025 L.E., but I guess we'll have to see the "PROs and CONs" list, before I can make that choice!
~rig~ Best to you Neil, Enjoy!
Old 03-23-2023, 09:58 AM #5
lewdog998's Avatar
lewdog998's Avatar
Originally Posted by rigtec View Post
Hi lewdog998,
~rig~ Enjoy!
Rig...
That is good to know....re the model of battery...is that the PC1500T? I know battery size has been beat to death on this forum, and searches turn up all kinds of results....but given our similar set up....does the 34r drop right in, or do I need a spacer etc?
I assume the 34 is better than the 24? The odyssey website configurator specs the 24. A link for your specific bat and spacer would be greatly appreciated.
Thanks
Lew
Old 03-23-2023, 11:33 AM #6
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Rig...
Thanks
Lew
Hi lew,
I had a 35_PC-1400 (same fitment as a 24 series) the 1'st time. When it came time to order another one, I called Customer Service, and was told that "it is (unfortunately) NO Longer made!" So I looked around and found the Odyessey 34R_PC-1500T! It sit's about 3/4 of an inch lower from top to bottom... so I just cut a wooden plank, 10" x 7"x 3/4", painted it to protect the wood, and used it as a height spacer; fits right in the tray [no need to buy anything EXTRA]!
I bought it on Amazon, cost: $397.00 w/FREE S&H ...arrived in two days! See photo below: Best to you!
High Power Alternator install-35r_pc-1500t-jpg
Old 03-23-2023, 11:54 AM #7
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
BTW:
I recently posted a thread, including a link: "How Odyssey Batteries are made"; an interesting study (IMHO):
How an ODYSSEY Battery Is Made - YouTube
"A bit off-topic, but relevant I believe; ~rig~ Enjoy!"
Old 03-23-2023, 07:32 PM #8
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Regarding "post #6" Above,
The EnerSys battery specs are almost ...IMPOSSIBLE to read; even when Enlarged! Here are the Odyssey 35R_PC1500T specs: CCA=850, HCA=1250, (Len)=10.85, (Wid)=6.76, (Hei)=7.88 (Height Includes Terminals); The length and width dimensions refer "ONLY TO" the top panel, NOT the bottom tray area! If you have any question wrt: Fitment of the 34R_PC1500T, Please hit me back here or shoot me a PM..!
~rig~
Old 04-01-2023, 03:08 PM #9
scfw0x0f scfw0x0f is offline
scfw0x0f is on a distinguished road
Excellent work @lewdog998 !
@DCPower_Anthony , will you be making any changes to that alternator to better work with the later model 4Runners, or create some more formal instructions on the the install process for 2018+ 4Runners?
Thanks for working this out!
scfw0x0f is offline   Reply With QuoteReply With Quote
Old 04-03-2023, 12:54 PM #10
DCPower_Anthony DCPower_Anthony is offline
DCPower_Anthony is on a distinguished road
Thanks to @lewdog998 for doing the leg work on this, really appreciate it.
We're taking measurements here and seeing if there is a different somewhere, I haven't heard of the spacing issue before so we're investigating it before we pull the trigger.. So still more to come!
Thank you guys
DCPower_Anthony is offline   Reply With QuoteReply With Quote
Old 04-03-2023, 12:54 PM #11
Thank you guys
Old 04-04-2023, 07:44 AM #12
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Hi lew,
@rigtec How long did your first battery last? I have a 34R PC-1500T coming up close to 4 years and its showing only 20% capacity. I filled out a warranty form but have not heard back from them in a week. Just curious what kind of life expectancy these batteries should have?
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 04-04-2023, 12:02 PM #13
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Originally Posted by jdm-v35 View Post
@rigtec How long did your first battery last? I have a 34R PC-1500T coming up close to 4 years and its showing only 20% capacity. I filled out a rigform but have not heard back from them in a week. Just curious what kind of life expectancy these batteries should have?
Hi jdm-v35,
My "35-PC1400 Odyssey Extreme" lasted 8 Full Years as of 2/23! The ODX-AGM-34R-1500" is new; but I expect No Less than the same! I assume you've checked/Upgraded the cables before condemning the battery(?)!
Here's a link to a thread that may be helpful to you; posted when I upgraded to the 34R-1500... "Good-bye Odyssey Extreme 35-PC 1400!"
~rig~ Best to you
Old 04-04-2023, 02:14 PM #14
Hi jdm-v35,
~rig~ Best to you
Thanks! I spoke with them and they are going to warranty it. I boosted the voltage to the correct range and my wiring is all 2/0 gauge. I bought a battery tester and that is how I figured out the battery was no good.
Old 04-16-2023, 09:04 PM #15
Thank you guys
@DCPower_Anthony , I see that you now have the vehicle years for the 270XP set to 2010-2021; does that mean it's ready for prime time? Any special instructions for mounting into the newer vehicles? Thanks!
alternator , bolt , engine , install , mounting
High Output Alternator Jrrrrr 5th gen T4Rs 1 06-07-2022 12:53 PM
Bad idle, no power, alternator/power issues? Falcon3 4th Gen T4Rs 8 08-16-2020 10:51 PM
WTB 4th gen 4.0 High Output Alternator Rocket61 Want to Buy/Trade 0 09-26-2015 02:50 PM
High Output Alternator? SixxiA Classic T4Rs 1 10-04-2008 01:21 PM
