Old 03-25-2023, 07:45 PM #1
AlumniCU's Avatar
AlumniCU AlumniCU is offline
AlumniCU is on a distinguished road
AlumniCU's Avatar
Any need to keep plastic trim above radiator?
Added winch today and need access for wired remote.
2015 Trail Premium w/ KDSS, OME suspension & UCAs, 255/80 17 Falken Wildpeaks, Hefty Banshee w/ Warn winch, RCI sliders & skids, all knockin' around the Rockies (~);}
AlumniCU is offline   Reply With QuoteReply With Quote
Old 03-25-2023, 07:52 PM #2
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
I'd say it could ensure that the airflow coming in through grille, flows through the radiator.
02SE is offline   Reply With QuoteReply With Quote
Old 03-25-2023, 08:25 PM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Mud, and water
Old 03-26-2023, 07:09 AM #4
Matt831 Matt831 is offline
Matt831 will become famous soon enough
I would keep it just from a cooling perspective.
Matt831 is offline   Reply With QuoteReply With Quote
Old 03-26-2023, 11:18 AM #5
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
No reason, its trim, for looks.
Top of radiator has sharp edges.
Mine has been off for years, same with that plastic cover on top of the motor, just for looks.
Zero noticeable effect on cooling with scan gauge 2.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 03-26-2023, 11:45 AM #6
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
It's there so you won't lose 10mm sockets.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 03-26-2023, 01:56 PM #7
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Its actually a staging area for "getting ready to lose" 10mm sockets.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-26-2023, 02:47 PM #8
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
Would't hot air from the engine get sucked into the radiator instead of cooler air? Not sure.
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 03-26-2023, 04:25 PM #9
It's not necessary under most conditions. But under severe service like towing max weight on a very hot day up a grade, at altitude, it can help keep the coolant temperatures in check.
Old 03-26-2023, 05:31 PM #10
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Personally I think it there for looks and to give the hood latch some slight protection from crud.
Some little strip of plastic is not going to do anything to adding cooling.
Some of these newer car motors are nothing but plastic cover mania when you pop the hood.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 03-26-2023, 06:57 PM #11
The idea is to direct all possible airflow through the radiator. For those situations where the engineers were trying to keep the engine temperatures controlled under extreme stress.
Presenting a more 'finished' engine bay would also be a consideration, but it is primarily a functional piece too.
I'm just basing my comments on those of a Toyota Engineer who mentioned it when asked in an interview when the 5th gen was being introduced, and seeing how airflow is managed on cars during my years of working on cars in consumer car repair, and professional racing.
access , iphone , today , winch , wired
Pinhole leak in plastic under radiator cap - is there a fix? hc803 4th Gen T4Rs 5 11-14-2022 01:35 PM
Best way to cut lower trim plastic? 03_4x4Runner 5th gen T4Rs 8 05-07-2015 12:57 AM
Help Removing Plastic Panel above Radiator MegaByte907 4th Gen T4Rs 7 04-27-2009 04:08 PM
removing wax on plastic trim? THES0FAK1NG Maintenance/Detailing 2 07-16-2008 08:42 PM
