04-09-2023, 08:17 AM
#16
Real Name: Ted A Hamilton
Originally Posted by HL4Runner
18 would be too wide and interfere with rear view mirror. Mine is 15. 16 would be perfect if they offer it.
Ignore my question on width, as I now see you do have the 15”. I plan to order and will see what they say about the clip not fully wrapping around. I have sent them the dimensions of the visor including thickness.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
04-10-2023, 07:47 AM
#17
Originally Posted by mrblah
i wonder maybe using a magnetic will help with the sagging..
Tired Velcro that I have at hand but wasn’t grabby enough to attach to roof liner.
Not sure how I can get magnets to stick to the area.
I might try some sort of semi permanent-ish double sided tape on the vanity mirror and light lense. This might also alleviate the 2-hand operation to deploy.
Starting to think I should have gotten the bolted on version.
04-10-2023, 11:25 AM
#18
Not sure either, that’s what the Land Cruiser forums suggested. Magnets on the visor and a tiny sheetmetal
Hidden in the headliner, etc.
04-10-2023, 01:55 PM
#19
Just ordered the 15” clip on
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
04-14-2023, 12:50 AM
#20
That's some great customer service right there.
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
04-15-2023, 01:23 AM
#21
Update: so the test mounts failed to cover the gaps completely and will require a complete redesign of the mount if they were to release a 4runner specific or tacoma specific visor in the future. They don't have a ETA as to when this will happen since this company mainly focuses on airplane applications, and not necessarily vehicle applications (unless there were dual applications already designed).
The current mounts offered are "universal" for a reason, it is to fit a multitude of platforms without needing vehicle specific mounts, so the mounts do not fit perfectly to each vehicle but are easily remedied (see DIY)
Vehicle specific mounts are really expensive. Rosen was kind enough to send me the schematics and allowed me to purchase an additional mount at wholesale to play with, and it wasn't cheap.
DIY solution: cut plastic spacers or 3d print some spacers to cover the gaps, and place the mount above it. This is perfectly suitable from a DIY standpoint, and will make any OCD person happy.
Currently, the interior of the vehicle is getting some forged carbon goodies, so I'll update ya'll when I get the chance to take some new pics or if I get off my butt and 3d print some spacers. I'm currently really happy with this setup, so making 3d printed spacers is on my very long list of "to do" projects.
Disclaimer: I am not sponsored by Rosen. I paid full price for the universal visors, and I received a test mount that didn't quite make it past my initial testing, and I paid wholesale for another test mount to play around with.
cheers!!!
04-15-2023, 02:12 AM
#22
I got the clip on version for driver side installed this past Sunday. Agreed on the thing is well made.
Slight issue with the clamp not able to wrap around fully due the the thick oem visor. But still very secure. Also now the oem visor sags about 1/4” from roof - I guess because of the added weight. Hardly noticeable.
The permanent install version do look very clean. But I didn’t want to remove the factory visor.
yeah i spent a few days trying to figure out which version to buy. I even changed my order at least once...lol.
It's hard for me to explain, but the overall attention to detail and design of the permanent mounting won me over.
I just like cool stuff.
04-16-2023, 01:16 PM
#23
Following up on my factory visor sag issue. After trying some velcro and tape methods that doesn’t really help. I learned that when not deployed, instead of folding the Rosen toward me, I flip it to face forward. Doing so put the factory visor back to its original closed position. This doesn’t block my driving visibility. Hardly noticeable looking ahead and from outside.
I’ll take a bumpy drive to see if it vibrates much. But I think problem solved.
04-17-2023, 12:22 PM
#24
Got my clip on today. Too hot to install now, so will wait for early morning
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
04-18-2023, 09:39 AM
#25
Installed this AM. Had to run an errand plus bumps on roads and noticed no sag as you described. Did have the OEM visor mirror end clipped in the retainer.
Also no 2 hand deploy as you noted. Perhaps you did not loosen the Allen Head screw a bit that allows easier deploy. I loosened it just enough to easily deploy with one hand but not enough to allow it to deploy by itself on a bump. Also keeping the OEM visor clipped at the mirror end assists in one hand deploy.
I am really happy with it and since the sun was just rising got to use it on several occasions. Great addition in my opinion and well worth the price.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
04-18-2023, 05:38 PM
#26
Great. One more thing to spend $$ on. Thanks a lot.
Nice review. Thank you for sharing.
04-18-2023, 06:45 PM
#27
Good to hear. Please share a couple of photos on how yours is clipped on. I might have mine too far toward the end…?
04-18-2023, 06:54 PM
#28
Will do, probably tomorrow
Did about a 30 mile trip today with some rough roads. No sag in the visor
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
04-18-2023, 10:27 PM
#29
yeah still loving mine.
Every time I use it, i have this habit of tilting my head sideways, forgetting i dont have to do that anymore...lol
04-19-2023, 08:21 AM
#30
Here is my clip on installed and deployed
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
