Old 03-27-2023, 11:50 PM #1
Mike Honcho Mike Honcho is offline
Mike Honcho is on a distinguished road
KDSS or other suspension options?
I have my choice of either a KDSS off-road or a non-KDSS off-road. Which to choose and why? I’ve read that it improves handling in curves and tippiness. That appeals to me. I could save some money buying the non-KDSS 4Runner because the other dealer is charging a $2,000 markup and of course the $1,750 initial price difference. Is there a suspension (coil over shocks) that anyone has tried that greatly reduces body roll? I’ve read Bilstein and Elka shocks are the ones to choose from.
Any advice would be appreciated. I’m on the clock here with deciding between the two. This color disappears quick when they hit the lots. Thanks!
Mike Honcho is offline   Reply With QuoteReply With Quote
Old 03-28-2023, 02:53 AM #2
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
I was initially planning on non-KDSS to save the money, with the intention of aftermarket suspension. Mine is a daily driver, with mild to moderate use in other conditions. It does see plenty of winter weather driving, mostly on road.
I ended up with a 2022 Off Road Premium with KDSS and I’m glad I did. The system really works to deliver on road handling and stability, which was noticeable when compared to the non-KDSS model I drove. In the end, it’s an expensive purchase either way so I looked at the long term viewpoint.
I did end up adding Bilstein 6112 front and 5100 rear, with the fronts including new coils. When combined with the KDSS it makes for an excellent setup.
I understand KDSS to be pretty reliable and trouble free, so only negative is that it automatically kicks in at a relatively low speed - I believe it’s 12-18 mph. Since I can see the potential for dirt/gravel/logging roads where I may wish to go over these speeds, but still have the added articulation of a non-KDSS model, I installed the Dr. KDSS plug-in module. This allows the system to be disabled, effectively leaving it in “open” mode at higher speeds. It’s the drivers responsibility to use good judgment and re-engage KDSS when back on the road.
If you shop around I’m sure you can find a model with everything you want at msrp.
That’s my experience, I hope it helps.
Hoppy
hoppyjr is offline   Reply With QuoteReply With Quote
Old 03-28-2023, 07:58 AM #3
Great first reply! I appreciate the detail.
My main issue with KDSS is just finding one. There are only two available within 500 miles of my location according to Toyota. One of those dealers wants to charge an additional $2,000 markup for the vehicle. So that vehicle is $3,750 more than a similar non-KDSS. Crazy!
Did the vehicle ride harsh and is that the reason you purchased replacement shocks? I’ve read that from some. How much do you have in the Bilstein shocks+installation? Just curious and I need a baseline for what I should pay if I go that route.
Thanks again!
Old 03-28-2023, 10:25 AM #4
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Another vote for KDSS if you are staying relatively close to stock. Mine drove amazing stock. Never felt it to be stiff or anything. I put on Fox 2.0s in the front and rear and absolutely love the way it drives. It's stiffer than stock, but in a good way. Even more controlled and much better rebound. I also have airbags in the rear which stiffen it up a bit. I too have the Dr KDSS switch makes it really the best of both worlds.
If you plan to go crazy with your build I'd probably just go with the normal TRD OR. That money could be used on a really nice suspension from Fox, OME, Icon, or King and KDSS would be just about useless.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 03-28-2023, 11:38 AM #5
Thanks for the reply. It sounds like KDSS is a great system. Does anyone know if an aftermarket suspension can come close to it? Which type? Thanks!
Old 03-28-2023, 12:41 PM #6
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
So the other thing you want to keep in mind is the limits of a KDSS system. The best lift that you could put on an OR truck is 2 - 3 inches over oem. Most people on here who have lifted more than that have wound up taking off their KDSS system because of the limits of the KDSS system with a lift.
Am another who has KDSS and loves it, after my 6 year warranty period (drivetrain only) am thinking of putting a small lift on my truck, along with the other Dr. KDSS lift accessories.
Good luck in your decision....Jim
2019 ORP KDSS MagGrey RSG Sliders/ICS Fab above console mount
Last edited by IslandJim; 03-28-2023 at 12:42 PM. Reason: maybe its 5 yr on the drivetrain
IslandJim is offline   Reply With QuoteReply With Quote
Old 03-28-2023, 12:58 PM #7
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
Thoughts
So having owned a Trail Premium w/KDSS a few years back and then switching over to a 2020 Pro with the Fox shocks and no KDSS, here are my thoughts.
Is the KDSS system good and worth it? Probably at $1750. I never modified the suspension on my 2016 as I only had it for about 2.5 years, but I did enjoy the way it drove. The one thing that KDSS did not settle down for me though was the really bad nose dive that you tend to get out of the stock suspension on these vehicles. I've never had that issue with my Pro whatsoever.
I would say I've enjoyed the overall ride and handle of the Fox system on the Pro, maybe even more so after putting the mild Eibach lifting shocks on it about a year after getting it. In a lot of ways, I think KDSS with an aftermarket suspension is the best way to go, but it would definitely NOT be worth $3750 to me when I could get a REALLY nice aftermarket suspension for the same money.
My recommendation would be patience with trying to find a KDSS without mark-up (or take a road trip to get one more like 500 miles from your home), or just go ahead and get a standard TRD offoroad and have the ~$4000 (including sales tax) to pump into modifications off the dealer's lot.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 03-28-2023, 01:04 PM #8
Ripper238's Avatar
Ripper238's Avatar
KDSS primary purpose is for off-roading articulation. But it also helps with handling over a stock 4R quite a bit IMO.
You can enhance on/off road handling in other ways but they usually only do 1 of the 2 better. Like a thicker sway bar on a SR5 will enhance on road handling more than KDSS, but you lose the off road articulation.
You can also go with a lift, better shocks and springs but then you lose some on road handling but get an awesome off road 4R.
The key is your usage. For me I do a lot on road driving but do Overlanding adventures every summer so I need the best of both worlds. And that's KDSS.
KDSS is more like $4000 to replace so keep that in mind when it comes to the value/comparison of it and if it ever needs to be replaced (though unlikely). Its a pretty ingenious system for under 2k, well worth it for the one who doesn't want to do a full suspension upgrade IMO.
Old 03-28-2023, 04:15 PM #9
Would something like Bilstein 6112 Strut&Spring Assembled+Rear 5100 Shocks for 10-23 4Runnerthis Bilstein combo offer many of the advantages of the KDSS? My goal is good stability on road in mountain curves without a harsh jarring ride, while also maintaining good off-road capability for driving on poorly maintained dirt and fire roads as well as some running around the farm and through the woods in the mountains to get to the trout streams. Maybe too much to ask from one suspension? I’m going deep into the rabbit hole here guys and much of this is out of my wheelhouse. I’m just used to throwing on a set of Ranchos and BFGs and sending her. I only have a few days left and I have to make a decision, so I do appreciate all of the input and wisdom.
Old 03-28-2023, 04:16 PM #10
Good addition and I felt the same. Under hard braking, especially if that stupid auto brake assist system kicked in, the nose dive was still very very pronounced. The Fox's helped that considerably.
Old 03-28-2023, 11:42 PM #11
IslandJim's Avatar
IslandJim's Avatar
Yes agree, no sports car driving unless you like nosedive! It does seem to leap off the line though : )
Old 03-29-2023, 01:27 AM #12
Thanks again!
It rode fine, but keep in mind that auto manufacturers create most vehicles for the average driver, in average use and conditions. If you deviate from average, it’s worth considering upgrades.
The 4Runner is a supremely capable vehicle in stock form, likely more so that most of us actually need. This said, the models below the TRD Pro have suspension tuning intended to be run with P-metric passenger car type tires. The Pro gets an uprated suspension to go with it’s all-terrain rubber.
I upgraded to BFG K02’s and they are both more aggressive and heavier weight, so I wanted to enhance the suspension to allow all my modifications to work together for increased performance.
You don’t need to make all those changes, and certainly not when it’s new. I’m just “that guy”.
Doing some shopping online I’m into the suspension parts about $1k. Figure another $350-500 for install and alignment, if you don’t install yourself.
There are other ways to go so don’t feel my path needs to be yours. I’ll gladly offer insight offline, so PM me if you’d like to discuss. My background is as an dealer service manager, then long time enthusiast with experience modifying over 50 vehicles for myself and family.
As to the dealer markup: check dealers out of your area too. Consider buying long distance, as you can fly out and drive back for less than $2k I’m sure.
Good luck with your decision.
Old 03-29-2023, 01:33 AM #13
KDSS is a unique system of hydraulic sway bars, so no springs & shocks will equal its performance. It’s a separate but equal thing, if that makes sense.
The member who mentions lift is correct; if you intend to do more than a couple inch lift I’d skip KDSS.
My truck came with a 3/2 lift from the dealer. I grew tired of it in a couple months, so I removed the lift and keep mine at stock height in the rear. The 6112’s bring it to level in front (about 1” higher than stock ORP, or equal to the stock TRD Pro).
i’ve , kdss , non-kdss , read , shocks
2011 SR5 Front Skid Plate options...non KDSS kjsayers 5th gen T4Rs 3 09-18-2022 08:35 PM
Lift Options For KDSS TRDDavid 5th gen T4Rs 21 05-10-2022 03:50 PM
2018 TRD ORP w/KDSS Level/Lift Options ripntear 5th gen T4Rs 26 08-13-2020 02:31 AM
New 4R Purchase: KDSS vs Non-KDSS with Modified Suspension and Added Weight? yellowdog 5th gen T4Rs 5 12-13-2017 01:32 PM
Options for Upgrading Non-KDSS Suspension on a TE jerlane 5th gen T4Rs 10 04-19-2012 06:47 PM
