Old 03-28-2023, 07:54 PM #1
Okusputokus's Avatar
Okusputokus Okusputokus is offline
Okusputokus will become famous soon enough
For rear LT setups, how long do the bump stops need to be?
For rear LT setups, how long do the bump stops need to be? My timbrens are 5", is that enough? I don't know what stock is and I know a lot of the kits recommend a 3-inch spacer on the stock bump stop.
At this point I'm leaning towards Dobinson MRR 3 way with LT rear.
Thanks for any help
2014 T4R Trail👉*LOTS of MODS
Okusputokus is offline   Reply With QuoteReply With Quote
Old 03-28-2023, 09:00 PM #2
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I just ordered Durobump bump stops for mine. I have a Radflo extended suspension setup and I got the 4.25” rear with the 0-3” fronts. My 4Runner is at about 3” lift with HD rear springs that have a height of 2.5”. If you have a 12” or longer stroke long travel shock, with 3”+ lift, then, Durobump recommends using the 5.25” rear stops.
I’m not sure about the other manufacturers.
https://m.youtube.com/watch?v=cahTrOM2BJI
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 03-29-2023, 02:39 PM #3
Thanks 🙏🏻
Old 03-29-2023, 10:38 PM #4
Jeremy556's Avatar
Jeremy556's Avatar
They need to be long enough that your shock is not the ultimate bump stop. Timbrens don't really count for extending bump stops - they move the initial contact point of the bumpstop lower in the suspension travel, but they are meant to compress a lot more, and don't change the ultimate bump stop point much. You need to extend the limit of your suspension travel.
If you don't have a direction from whoever is supplying the shock, remove your springs and fully articulate your axle and figure out where the shock hits full compression. Make bumpstop adjustments to make sure you never hit that full compression, and remember that rubber compresses, including bushings in the control arms, so leave yourself some safety margin.
Looks like you might have ARB KDSS skidplate in your profile pic - hopefully you have removed your KDSS, because it isn't going to work with LT shocks
bump , long , rear , stock , stops
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
rear bump stops Herculean T4R 3rd gen T4Rs 2 01-08-2018 12:20 AM
Rear bump stops raygenjay 4th Gen T4Rs 2 06-19-2017 12:30 PM
Rear bump stops WXman 4th Gen T4Rs 10 10-16-2013 04:59 PM
WTB: 1996-1997 Stock(extra long before recall) 4runner bump stops JayRolla Want to Buy/Trade 0 03-15-2012 12:34 PM
