Appreciate the info everyone. Prior to oil change, all old oil was 100% drained. then filled with 6.5 quarts per owner's manual of Toyo OEM oil with new OEM filter. Clearly 6.5 was too much.
Although I would have likely been fine as many have said, I bought a
hand pump at Auto Parts store and pumped out 1 quart to get oil level lowered back to the high Fill Line
Reading past posts on the topic, it seems many here use 5.5 quarts. Something also strange about T4R dipstick that makes reading hard.
Next oil change my truck will get 5 quarts and then I will add as needed over the following days.
