03-30-2023, 03:17 PM
Real Name: Jo
Real Name: Jo
Oil Change Overfill
I read that even 1/2 quart too much engine oil can increase engine pressure. This looks like an overfill of about 3/4 quart.
I am unsure how concerned I should be.
03-30-2023, 03:38 PM
I am not a doctor or a lawyer or a mechanic.
Oil pressure wise, this is determined by your oil pump. As long as it has the ability to get oil and distribute it you're fine.
If the crankcase is so full that a) the oil can't return from its journey or b) the oil is in contact w/the bottom of the crank and potentially "frothing" then this could cause an issue. I'd look for foam/froth on the dipstick after a drive.
IMO you should be OK.
On a semi related note: does anyone know if a top-end (through dipstick) oil extractor will work with a 4runner?
'22 4runner Limited (ORP 17s)
'18 MacanS (wife's)
'10 997S
03-30-2023, 04:40 PM
I don't see why not. If the dipstick goes down there a tube should too.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
03-30-2023, 05:03 PM
Real Name: Rich
Real Name: Rich
I would put a clean catch basin under the car and take the drain plug out. It shouldn't take but a second or two. I'd save the oil and use it another time... or in my chainsaw.
Better to be a quart low than a quart too much. The frothing is what I have heard is the problem. The crankshaft is aerating the oil and it doesn't lubricate properly.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
03-30-2023, 05:28 PM
These dipsticks are incredibly difficult to read with fresh synthetic oil in there.
My experience, slight overfill and you are ok. Significant overfill and you risk blowing seals like on the crankshaft. Once that happens, you are in for some expensive repair work. Based on what I see here on my iPhone, I would reduce that oil level.
You can either drain some off through the drain plug, or draw some out through the dipstick using a pump and a long straw or tube.
03-30-2023, 06:39 PM
Real Name: Jo
Real Name: Jo
Thanks for the feedback all
03-30-2023, 09:51 PM
I am sorry to break-in late into thread, it looks closed issue. However, try take oil reading while engine in idle - that's the proper level. And if anyone interested: does someone noticed that thread on Toyota oil quart bottle exactly the same as thread on engine oil filler neck? picture for reference:
03-30-2023, 10:00 PM
What? No! That is bad information. Oil level on regular dipstick vehicles is taken when warm and engine off.
BMW and other fancy oil level checks are different and may or may not be while engine running, but they also donÂ’t have a dipstick.
IÂ’ve found it really difficult to check the oil level with 0w-20 and stock dipstick, but yours does look a bit overfilled.
Reason: Changed cold to warm
03-30-2023, 10:33 PM
Originally Posted by Bmnorm2
What? No! That is bad information. Oil level on regular dipstick vehicles is taken when cold and engine off.
BMW and other fancy oil level checks are different and may or may not be while engine running, but they also don’t have a dipstick.
I’ve found it really difficult to check the oil level with 0w-20 and stock dipstick, but yours does look a bit overfilled.
I don't have the manual on hand but majority of the vehicles I've worked on needed the oil at operating temp before measuring on the dip stick.
OP, since I don't know if you did a wipe off and then a quick insert and removal I will assume you did so.
IF it bugs you enough I would advise draining some oil for max efficiency. It's better to have NOT enough oil vs. TOO MUCH oil in most cases.
You can either crack the drain plug for a moment OR get a vacuum pump with reservoir and pull some out.
Drive around 10 miles and then check the dipstick for any aeration. If you see some then I would advise drawing some oil out.
03-30-2023, 10:46 PM
You are correct, oil should be warm. Corrected my post. I was flabbergasted by the idea of checking dipstick while engine idling. All of the oil should be settled back into pan when checking.
Page 410 of owners manual for procedure.
Warm up, turn off, allow 5 mins for oil to drain back into pan, pull dipstick and wipe clean, reinsert, remove and observe level.
03-31-2023, 12:40 AM
Real Name: Jo
Real Name: Jo
Yes, with engine cold, withdrew dipstick, wiped, inserted and quickly removed/ read dipstick.
03-31-2023, 12:43 AM
Real Name: Jo
Real Name: Jo
Seems like I need to check when engine is not completely cold
03-31-2023, 08:22 AM
Real Name: Ron
Real Name: Ron
Take oil filter off and drain, repeat several times.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
03-31-2023, 05:21 PM
Doesn't really make a difference. Oil doesn't suffer anywhere near the same expansion under heat that ATF does.
Now with ATF, it should be at a certain temp and idling. Some vehicles require trans in Park, some require N.
Sent from my SM-S901U using Tapatalk
03-31-2023, 09:09 PM
Yes, an oil extractor will work. I used a Mityvac twice through the dipstick with an extraction tube through to the bottom. I pulled the drain plug both times to see how much was extracted. First time practically everything. Second time about a quart left.
It helps to extract the oil when it’s warm. I find that extracting takes longer than a regular drain procedure. Thus, I have reverted to normal draining from the plug. You’ll be certain all the fluid will be drained.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
