Old 03-31-2023, 02:00 PM #1
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a name known to all lewdog998 is a name known to all lewdog998 is a name known to all lewdog998 is a name known to all lewdog998 is a name known to all lewdog998 is a name known to all
lewdog998's Avatar
Odyssey battery confusion...help
Ok...I have seen lots of threads and done the reading, but I cant figure out why everyone is recommending the group34 battery with a bottom spacer. If you go to odyssey site, and plug in a 2020 4r....it suggests the ODX-agm24f.....
the forum consensus is the 34r-pc1500. From my research they are both "extreme" agm units. The 24 is slightly taller and does not need a spacer...and the specs are virtually the same with a notable longer reserve cap of the 24.
WHAT am i missing???? Is it the weight?
Battery dead on my LC100, gonna take the 4r batt and place in LC100....then use the new odyssey in the 4r.
34r-PC1500
10.9 x 6.8 x 7.9 high (post included)
PHCA 1500A
CCA 850A
Resv cap 135 minutes
49lbs
odx-agm24f
10.9x6.8 x 8.8 high (post included)
PHCA 1500A
CCA 840A
Resv cap 160 min
57 lbs
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-31-2023, 05:33 PM #2
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
Not an expert on this
The R in 34r-PC1500 is for the reversed terminals which is the stock terminal location in the 4runner.
The 24F should be flat terminal layout but I have no idea what that is. I have a 34r and it works fine for me although I'm using the rago battery box with no riser.
I also know of some people who do a group 31. Be careful how big of a battery you install, the heavier ones are known to crack the front apron support above the wheel.
I'm pretty sure you can just use what ever fits or works for you
NorthPark is offline   Reply With QuoteReply With Quote
Old 03-31-2023, 10:07 PM #3
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is a jewel in the rough rigtec is a jewel in the rough rigtec is a jewel in the rough rigtec is a jewel in the rough
rigtec's Avatar
Real Name: Greg
34r-PC1500
PHCA 1500A
CCA 850A
49lbs
odx-agm24f
PHCA 1500A
CCA 840A
Resv cap 160 min
57 lbs
Hi lewdog998,
The group 34 has a bit more CCA than the Group 24 unit, but they'll both fit in the battery tray just fine! The 24F doesn't need the spacer underneath it to mount up!
~rig~
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 04-01-2023, 12:41 AM #4
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
34r-PC1500
PHCA 1500A
CCA 850A
49lbs
odx-agm24f
PHCA 1500A
CCA 840A
Resv cap 160 min
57 lbs
The problem with the odx-agm24f is that the terminals are in the wrong place. You need to modify the cables to reach properly. Pain in the ass really. If you can find an equivalent group 24 with reversed terminals then that would be the better choice. I don’t think odyssey makes such a thing.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 04-01-2023, 12:57 PM #5
Kunimatsu's Avatar
Kunimatsu Kunimatsu is offline
Kunimatsu is on a distinguished road
Kunimatsu's Avatar
I went with the X2Power Premium AGM 24F. No riser, or cable location issues, plus it has a 4 year warranty.
Batteries Plus link
Kunimatsu is offline   Reply With QuoteReply With Quote
Old 04-01-2023, 04:54 PM #6
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
The difference between 24 and 24F is that the terminals are reversed. 24F fits the T4R without modification, and yes, Odyssey makes one.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 04-01-2023, 06:28 PM #7
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
When i put my 1st Odyssey battery in my 2014 4runner sometime around 2018
the 32R battery was the one recommended by Odyssey and I bought it directly from them. When i decided to replace it last year they recommended the 24 battery. Possibly they did not make a reversed terminal 24 battery in 2018? Either one works just fine.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 04-01-2023, 09:49 PM #8
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
Not helpful to your question but i highly recommend the X2 from Just a moment...
I had their previous brand (north star) for almost 8 years and only replaced it because the voltage was running low. Not totally dead.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 04-02-2023, 02:07 PM #9
Interesting. The images on a lot of sites must be out of whack then. However going to Odyssey's site shows both an ODX-24F and an ODP-24F as fitting the 4runner. No idea whatsoever the difference between OD Performance and OD Xtreme.
Anyway, if I'm wrong that's a good thing. I've done the terminals in the wrong place thing before and it's a fkn pain in the ass to say the least.
Gone
Old 04-03-2023, 10:23 AM #10
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
The biggest issue is the terminals are backwards, I actually tried putting a 24 in and it would not work without extending the battery wires and terminals
2017 Nautical Blue SR5 Premium - Black Emblems, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, VR ECU Tune, RCI Skid Plate, Morimoto MLED 2.0 Headlight Retrofit, Morimoto LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Tinted Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, CaliRaised Rock Sliders, BajaRack Full Length Roof Rack, Kenwood DMX1057XR, Infinity Kappa Door Speakers and 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, Blackvue DR900S Dash Cams
34r-pc1500 , battery , cap , odyssey , post
Odyssey Battery Röde Orm For Sale: Non-T4R Items 3 06-28-2021 08:31 AM
Odyssey Battery Charging Louisiana Overland 5th gen T4Rs 10 03-14-2020 07:11 PM
Hunter Odyssey Battery eurasiaoverland 3rd gen T4Rs 10 03-01-2018 11:09 PM
Odyssey Battery tigger 5th gen T4Rs 14 06-08-2017 03:27 AM
Odyssey Battery nytefog 4th Gen T4Rs 6 03-05-2011 06:34 PM
