Old 04-03-2023, 09:18 AM #1
Sir.T.Grant Sir.T.Grant is offline
Sir.T.Grant is on a distinguished road
Electrical Gremlins Reverse Polarity - 5 Hours into Fix - Struggling with Next Steps
Good Morning,
Situation: While I was out of the country, an unnamed Family member attempted to use my 4Runner and attempted to "jump start" it using jumper cables. Unfortunately she managed to reverse the polarity (switching pos/neg) and kept the cables connected for over 5 mins.
Corrective Action Taken to-date:
1) Replaced Battery
2) Replaced Alternator (that was fun...)
3) Replaced all the blown fuses in the engine compartment fuse block including the 60 AMP alternator fuse.
Current situation: 4Runner starts when battery is fully charged. and it seems to maintain a charge for 5-10 mins. Then the battery quickly (within 4 mins) drops from 12.2volts to <10volts and the car fails and needs to be (correctly) jump started. The 4Runner illuminated dash lights for Traction Control - ABS - Battery Icon - and BRAKE. The only other observable issue is the A/C does not work but the FAN does...
Does anyone have a suggestion for a next course of action? What to check to possibly replaced?
Sir.T.Grant is offline   Reply With QuoteReply With Quote
Old 04-03-2023, 09:23 AM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by Sir.T.Grant View Post
Good Morning,
1) Replaced Battery
First thing to do is check the battery voltage while the engine is running. If the voltage is 14.1 volts or a bit higher, that shows the alternator and charging circuits are working. If all you are getting is 12.2 volts with the engine running, the battery is not being charged.
A sudden drop of the battery from 12.2 to 10 volts indicates a bad cell in the battery (each cell is 2 volts since there are six cells in a 12 volt battery).
fkheath is offline   Reply With QuoteReply With Quote
Old 04-03-2023, 09:32 AM #3
Instant Check.
Thank you for the quick response. I tested the battery prior to starting and it read 12.9volts. Ran it for six minutes and it held in the high 12s for 5 mins then feel off precipitously and dropped to 11.0/10.9 before I turned off the rig.
Old 04-05-2023, 08:27 PM #4
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Alternator not providing correct charging voltage
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 01:18 AM #5
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Good Morning,
1) Replaced Battery
Hi Sir.T.Grant,
There are a couple of things I would be testing for in that situation:
(1) The 140A Alternator Main fuse, and pull/check ALL fuses in D/S & Engine RM boxes, (...I'll post a electrical diagram below for Main ALT fuse)! And check... (2) Center Point Steering Calibration & Yaw Rate Acceleration Calibration!
If those two calibrations are "NOT" Set properly, you'll get EXACTLY as you've described on the instrument cluster, e.g. ABS, SKID, BRAKE! ...see diagram 140A fuse highlighted in Blue to determine if it's Blown; [NOT(conveniently) Replaceable]:
~rig~ Best to you!
Electrical Gremlins Reverse Polarity - 5 Hours into Fix - Struggling with Next Steps-4runner-starting-charging-diagram-jpg
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 06:54 AM #6
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
What brand of alternator did you put in? The reason I ask is that I've seen way too many parts store (particularly O'Reilly's) alternators arrive DOA.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 04-07-2023, 01:03 PM #7
Updates.
1) Replacement Alternator was a brand new (not remanufactured) WAI Global.
2) On the recommendation of some team members, I have verified the 140A that was replaced is still in tact. Further. I checked every single fuse both in the engine compartment and driver's footwell. I am still not having any issue.
At this point I am at a loss for what to check next? Any suggestions/hopes/prayers?
Electrical Gremlins Reverse Polarity - 5 Hours into Fix - Struggling with Next Steps-img-5742-jpg  Electrical Gremlins Reverse Polarity - 5 Hours into Fix - Struggling with Next Steps-img-5741-jpg
Old 04-07-2023, 02:59 PM #8
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Hi Tyler,
In the above post, you said: "I am still not having any issue.
At this point I am at a loss for what to check next? Any suggestions/hopes/prayers? "
Is that what you meant to say or, "I am STILL having an issue...(?)!" Just checking to make sure I'm understanding correctly here! If you ARE still having this issue... check a few of these Commonly overlooked test points: At the alternator's pins, S (Vio), B (WH), IG (Gry), and L (Pink): M (Blu)= Monitor/CAN-bus; I'm not sure what that value should be!) With the Alternator's plug disconnected and power "ON", test for 12V in the plug cavity!
If you have 12V at S, IG, and L..., Time to do a ECU Master RESET to make sure that the CAN-bus system isn't preventing the alternator from charging; I've had that happen to me while driving..., "Yaw Rate and Center Point Steering Cali needed at the time!!"
Disconnect the battery! Using a small jumper, jump the POS and NEG cables together for 10 minutes; it shouldn't take that long, but we wanna do this only ONE TIME! Reconnect the battery cables to the battery and start the truck. It'll start, run for 2 seconds and SHUT-OFF; this is "NORMAL!" That just verifies that the ECU's have been RESET! If it's charging, we're GOOD! If not...,
There's one more thing that I would do to check that the alternator has what it needs to produce a charge. Get a 4ga x 19" battery cable, and run it from the B terminal on the alternator to the POS terminal on the battery (Back-feeds the ENG-RM fuse-box), and test the output; should be +/- 13.5-14.0 if it's working! I know it a pita, but we don't wanna miss any steps in the analysis process!
~rig~ "Please let us know... or questions!"
4runner , battery , mins , replaced , reverse
03-09 HVAC & ODO Reverse Polarity Kit NearlystocK 4th Gen T4Rs 0 10-05-2021 06:35 PM
4th Gen Reverse Polarity Kit NearlystocK 4th Gen T4Rs 6 07-26-2021 10:33 PM
Reverse Polarity Kits 15 percent off all November!! Johns06yota 4th Gen T4Rs 10 06-13-2020 07:08 PM
Electrical Gremlins MTn_man 4th Gen T4Rs 3 01-23-2020 12:50 PM
Sale all November!! 15% off reverse polarity kits Johns06yota 4th Gen T4Rs 0 11-09-2019 10:14 PM
