04-05-2023, 08:41 AM
Audio Upgrade?
Hello all:
I have a 22' SR5 Premium and I hate the speakers.
I have found two "plug and play" kits and I was wondering if anyone had experience with either one or if there are any other options out there?
I am looking at just speakers for now and possibly adding an amp and bass later one.
I found the OEM Audio Plus set for $649 and the Trail Grid Pro Kicker set up for $588. The kicker seems to have a few more adapters and wiring to do than the OEM system.
Any feedback would be appreciated.
Pat
04-05-2023, 10:05 AM
Originally Posted by Skip2a
Hello all:
Pat
I have the OEM Audio Plus speakers and they sound great -- crisper highs and a bit more bass. I avoid anything that requires adapters or cutting/spicing/tapping the wires.
04-05-2023, 10:35 AM
My installer set me up with Focal for my doors. Direct fitment. Huge improvement over the quarter sized OEM magnets of course. Aftermarket deck went in a couple weeks later as it was on order but hearing those with the factory stereo was a tremendous improvement. I had already replaced the tweeters myself. Anyway, Focal is a quality replacement for sure and not overly expensive I think in comparison with others.
2017 TRD OR / KDSS / Canuckistan Edition
04-05-2023, 03:49 PM
Real Name: Mark
Real Name: Mark
I upgraded both of my 4Runners with Kickers all around incl. 3/4" silk dome tweeters.
`Yota stock Rear and Hatch speakers are pathetic tbh.
I used 3-way 6x9's for the front door (sound stage) 150RMS, and 6-1/2" 2-way for the rear door 100RMS as well as 5-1/4" 2-way speakers for the hatch 75RMS.
If you order through Crutchfield they usually throw in the spk adapters and metra harnesses at no charge.
BTW: BOSS makes a decent 800w discrete all-in-one Sub that easily fits under the passenger seat - to bring the boom!
Good luck!
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
04-06-2023, 07:23 AM
Thank you all for the responses.
I tried Crutchfield but they didn't list anything except for the front doors. I will need to give them a call. I have put in a few systems from them and they are incredible as far as customer and tech service goes.
Pat
04-06-2023, 10:46 AM
Real Name: Mark
Real Name: Mark
My 5th Gen Speaker upgrade/setup.
I know it can sometimes be a bit confusing. The automated system at Crutchfield isn't anything more than their vehicle specific recommendations. I did the research before pulling the trigger and my 5th Gen 4Runner now has a great low budget sound system without modifying the stock vehicle wiring.
Lower Front Door/Rear Door: (I installed in Rear Doors) Crutchfield says it won't fit Rear but I used the Kicker OEM spk adapter just fine)
*SEE ATTACHED PHOTO PROOF*
Kicker 47KSC6504
Kicker 47KSC6504 KS Series 6-1/2" 2-way car speakers at Crutchfield
Dash Tweeters: (Component speaker system includes 2 woofers, 2 tweeters, and 2 crossovers)
Kicker 46CSS694
3/4" titanium dome tweeter
Lower Front Door: (Component speaker system includes 2 woofers, 2 tweeters, and 2 crossovers)
Kicker 46CSS694
Kicker 46CSS694 CS Series 6"x9" component speaker system at Crutchfield
Hatch:
Kenwood KFC-1396PS
Kenwood KFC-1396PS Performance Series 5-1/4" 2-way car speakers at Crutchfield
Subwoofer:
BOSS Audio Systems BAB8 Amplified - 800 Watts Max Power, Low Profile, 8 Inch Car Subwoofer
Amazon.com
Head Unit: (In case you're interested)
Boss BV800ACP
Boss BV800ACP Digital multimedia receiver (does not play CDs) at Crutchfield
04-06-2023, 01:27 PM
Real Name: Jared
Real Name: Jared
TacoTunes also has a system that integrates in with the factory head unit.
Just about anything is an upgrade over the factory stuff.
I'm running JL Audio: Fr to R - 3.5, 6x9, 6.5, 6.5, 2x 8" (w3's, have a single 10 in the works). It'd be much better with an aftermarket head unit for sure, but a complete system overhaul will happen eventually.
*'16 Trail - JBA UCAs, Toytec BL, Dobinsons FR, Radflo LT Rear, (~3.5F/4R total lift) 285/70 (/75s next), mix of HeftyFab/SSO steel goodies
04-06-2023, 02:51 PM
Real Name: Mark
Real Name: Mark
I upgraded both of my 4runners back-to-back to incl. soundproofing and other retrofit mods. It was a challenging but rewarding project for a DIY.
I actually have a theory that my dual JL w6v2's could be used for extra propulsion with the massive amount of air they move. hehe
04-06-2023, 03:06 PM
Real Name: Chris
Real Name: Chris
Pat
I bought all my speakers from Crutchfield and did the installs myself, if they don't provide the speaker mounting adapters I got mine from TacoTunes and just mounted them and installed them myself. These wire adapters are all you really need
https://www.amazon.com/RED-WOLF-Repl...s%2C141&sr=8-3
and these for the tweeters
https://www.amazon.com/RED-WOLF-2010...NsaWNrPXRydWU=
04-07-2023, 08:25 AM
Hello all:
Pat
best piece of advice you will receive regarding install of door panels!!!
reinstalling the door panel try not to remove the window sill part! I struggled with it for about 20 minutes and stepped away. After a few searches I found out that was my issue. I reinstalled the window sill and then panel, it took all of 2 minutes.
https://www.toyota-4runner.org/2294986-post50.html
04-09-2023, 05:12 PM
Did you notice an increase in the volume overall?
I have a ‘21 TRD OR and I find that I often have to nearly max out the volume to get the volume I want sometimes.
In other vehicles, I’ve always been happy at around 50%
04-09-2023, 05:32 PM
almost any speaker would be an upgrade over stock speakers, but some aftermarket would need more power to them. Use an amp or an aftermarket stereo . I have a sony 8100 and love it but want a factory look, and finally purchased a 2022 head unit. I don't think it will have enough power for the focal speakers i have so Ill probably buy an amp .
