Old 04-13-2023, 07:36 PM #1
DwightS DwightS is offline
DwightS is on a distinguished road
Remote Start not working
This may have been asked before but my search didn’t turn up exactly what I’m experiencing.
2018 4Runner SR5 Premium, we purchased the truck used about a year and a half ago. When we first got it, the remote start worked with the factory Toyota key-remote. Now, when you use the remote, the truck will try to crank, but won’t start. And when you get in the truck to try to start it with the key, it still won’t start. We found that you have to jump the battery (using a jump box) to get it to start and run.
Any ideas? We’re just ready to trash the remote start…
Thanks for any feedback
DwightS is offline   Reply With QuoteReply With Quote
Old 04-14-2023, 09:20 AM #2
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
This may be a dumb question, but did you have the battery tested?
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 04-14-2023, 01:48 PM #3
The battery is only a few months old. The remote start quit working a couple of months after we bought the truck. The battery was replaced just a few months later.
Old 04-14-2023, 01:55 PM #4
Humble Leader's Avatar
Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all
is it a toyota OEM remote start or aftermarket?
Old 04-14-2023, 02:59 PM #5
To the best of my knowledge, it’s Toyota. It uses the Toyota 4Runner remote/key.
Old 04-14-2023, 04:30 PM #6
troubleshooting a remote start that doesn't work can be a nightmare. aftermarket kits also can use the fob, like accessorides. you can remove the remote starts with a lot of patience and care by cutting off the splices and covering any exposed wires. something like accessorides that is plug and play is very easy to remove
do you know where the control module is? it's probably tucked up behind the trim by the steering wheel as remote starts will often splice into wires back there as well as the ignition wires.
if it's an OEM remote start and you know it was installed by a dealer you can try and have them troubleshoot it. but if it was a DIY install you could be chasing for days to find the cause (assuming battery and other fobs are not the issue)
Old 04-15-2023, 10:16 AM #7
aggrobot's Avatar
aggrobot aggrobot is offline
aggrobot will become famous soon enough
aggrobot's Avatar
This sounds like an electrical gremlin. What, if any mods have you done, particularly anything involving any wiring or rewiring?
‘21 Limited Nightshade//O.T.T. Tuned//Eibach Stage 2R//Dobinsons UCA//Method 316//Cooper AT3 4S - 285/70/r17//KTJO Drivers Side Grab handle//Tuxmat!
aggrobot is offline   Reply With QuoteReply With Quote
Old 04-15-2023, 05:02 PM #8
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
FWIW, the remote start control unit Toyota uses as a factory/port option often doesn't last. I went through several issues where remote start wouldn't work, but you could turn the key and it would start just fine. I ended up paying to remove the dead factory crap and then went to somewhere else and had them install a quality CompuStar system. I've had no issues since, and my only regret was not doing that when I bought the truck at the start.
Am I reading this right though? You need a jump-pack to start the truck normally (not remote) after the remote start attempt fails? I assume you don't need the jump pack normally to just start the truck? That doesn't sound like a fun issue to troubleshoot. My first thought is a vermin chewed wire related to the remote start control unit. Or possibly something with the immobilizer not getting proper power?
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
jump , remote , start , truck , won’t
Toyota VIP remote engine start stopped working pitstain 5th gen T4Rs 9 08-19-2020 04:03 PM
Had fuel pump recall done remote start stopped working BigCountryT4R 5th gen T4Rs 9 02-25-2020 08:26 PM
Remote start not working after wreck. vondy21 5th gen T4Rs 3 10-21-2017 01:35 PM
Remote starter is working but anti-theift won't let the car start !? Mchabot001 4th Gen T4Rs 16 12-06-2013 12:24 PM
Remote Start Stopped working! jheight84 4th Gen T4Rs 0 11-16-2011 02:46 PM
