Originally Posted by DwightS
To the best of my knowledge, it’s Toyota. It uses the Toyota 4Runner remote/key.
troubleshooting a remote start that doesn't work can be a nightmare. aftermarket kits also can use the fob, like accessorides. you can remove the remote starts with a lot of patience and care by cutting off the splices and covering any exposed wires. something like accessorides that is plug and play is very easy to remove
do you know where the control module is? it's probably tucked up behind the trim by the steering wheel as remote starts will often splice into wires back there as well as the ignition wires.
if it's an OEM remote start and you know it was installed by a dealer you can try and have them troubleshoot it. but if it was a DIY install you could be chasing for days to find the cause (assuming battery and other fobs are not the issue)
