Originally Posted by mctizzo
Was in the Middle of Installing my AlphaRex Headlights, and I need to connect into the turn signals/DTR in order to make the Turnsignals in the lights run..
the problem is when the installer installed my bumper 10+ years ago, they clipped my turn signal connectors and just hardwired them.
I need to wire in new connectors to make the lights work as intended..
Can anyone help?
Thanks.
If you want OEM connectors, it can be done but takes time and hard to do.
1. Every connector that Toyota uses at the factory has a part number. The challenge is to find the part number. With the part number, virtually all connectors can be ordered from you dealer or on line. Quite often, the connector has the part number molded into the connector housing. It will be very, very small, so you will need a bright light and a magnifying glass.
2. You can also find the part number by looking on the OEM wiring diagram (available on TIS or your dealer). The wiring diagram will show a reference number which can be cross referenced to the part number which may be at the end of the wiring diagram. Wiring diagrams come in sections, so you would need to look under lighting section, subsection for fog lights.
3. You can look up the details on most Toyota connectors here:
https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf (yes, I know it says RAV4, but it really applies to all Toyota connectors).
