Old 04-21-2023, 04:56 PM #1
mctizzo mctizzo is offline
mctizzo is on a distinguished road
Need to buy these connectors to make my Lights work.. Don't know what they are.
Was in the Middle of Installing my AlphaRex Headlights, and I need to connect into the turn signals/DTR in order to make the Turnsignals in the lights run..
the problem is when the installer installed my bumper 10+ years ago, they clipped my turn signal connectors and just hardwired them.
I need to wire in new connectors to make the lights work as intended..
Can anyone help?
signal-2023-04-21-154247-002 hosted at ImgBB — ImgBB
[IMG]yt-JUD0-Vj-K0[/IMG]
[IMG]signal-2023-04-21-154247-003[/IMG]
Thanks.
mctizzo is offline   Reply With QuoteReply With Quote
Old 04-21-2023, 06:30 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Junkyard is probably your best bet, or a junkyard search site
Rich
2004 V8 4Runner 138K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 04-21-2023, 07:50 PM #3
Are they universal?? I thought brand specific
Old 04-22-2023, 11:08 AM #4
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
I wonder why the bumper installer cut off the plugs from your vehicle and hard wired the connections; very odd.
If you ordered the new lights for your specific vehicle then they should have come with the proper connectors. Find a junkyard that has your make and model of T4R and get the connectors that were cut off. Get both sides of the connector, male and female, and compare to the ones on the new lights. If they are the same then you just need to splice the junkyard connectors back onto the wires where the OEM connectors were cut off.
One other option is to cut off the connectors from the new lights and just splice them onto the old wires without connectors, like they are now.
Rich
Kentucky
Old 04-22-2023, 11:29 PM #5
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Can anyone help?
Thanks.
If you want OEM connectors, it can be done but takes time and hard to do.
1. Every connector that Toyota uses at the factory has a part number. The challenge is to find the part number. With the part number, virtually all connectors can be ordered from you dealer or on line. Quite often, the connector has the part number molded into the connector housing. It will be very, very small, so you will need a bright light and a magnifying glass.
2. You can also find the part number by looking on the OEM wiring diagram (available on TIS or your dealer). The wiring diagram will show a reference number which can be cross referenced to the part number which may be at the end of the wiring diagram. Wiring diagrams come in sections, so you would need to look under lighting section, subsection for fog lights.
3. You can look up the details on most Toyota connectors here: https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf (yes, I know it says RAV4, but it really applies to all Toyota connectors).
fkheath is offline   Reply With QuoteReply With Quote
connectors , lights , make , turn , work
Any way to make Homelink ONLY work when key is on? spetka 5th gen T4Rs 44 04-06-2023 08:48 AM
Got some Jeep aftermarket fog lights. Is there any way I can make it work? PeoplecallmeIan 5th gen T4Rs 3 08-14-2018 02:50 PM
3rd gen factory fog lights and connectors $80.00 shipped Tucson4runner For Sale: T4R Items 14 04-10-2016 09:19 PM
2007 4runner lights, horn and blinkers work, but hazard will not work rki1966 4th Gen T4Rs 1 09-21-2014 02:08 PM
can we make the fj's snorkel work for us? jam23r1 5th gen T4Rs 18 05-25-2011 08:39 PM
