Old 04-22-2023, 10:40 PM #1
The_Mickstar The_Mickstar is offline
The_Mickstar is on a distinguished road
Will emblem tape (like 3M VHB) stick to bedliner?
Does anyone know?
I sprayed the bumper valances on my TRD Off Road with Rustoleum spray-on bedliner, and I'm considering spraying my aftermarket TRD Pro grill bar so that it matches (color & texture). I'm concerned the TOYOTA letters may not stick well to the bedliner, though.
The_Mickstar is offline   Reply With QuoteReply With Quote
Old 04-22-2023, 11:12 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Originally Posted by The_Mickstar View Post
Does anyone know?
It is my experience that 3M double sided sticky tape sticks best on smooth surfaces, such as paint. On rough surfaces, it doesn't stick as well.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-23-2023, 05:36 PM #3
Humble Leader's Avatar
double sided tape is all about preparation. isopropyl alcohol to clean first then heat the tape and surface gently with a heat gun. if there's a lot of texture (deep ridges) you might have issues but that tape does conform. make sure you use the extreme version of 3M
FWIW I used double sided tape (scotch extreme double sided tape) to run a couple of aluminum flats on the bottom sides of my two roof top boxes and that tape was applied over a year ago. went through 2 summers and one winter and that aluminum is basically cemented on there. not lifting at all. I've used it to secure my ham radio display unit brackets at well and no issues there
Old 04-24-2023, 01:24 AM #4
4skrunner 4skrunner is offline
4skrunner will become famous soon enough 4skrunner will become famous soon enough
Try 3m adhesion promoter. Look it up on Amazon
4skrunner is offline   Reply With QuoteReply With Quote
aftermarket , bedliner , spraying , stick , trd
Does anyone know what adhesive i can use to stick a custom emblem on? JohnLocker General Discussions 6 01-09-2022 03:20 PM
spray on bedliner vs roll on bedliner jad4zyx Classic T4Rs 9 05-21-2019 03:57 PM
What Bedliner is the BEST ***Poll***** Thorgan112 General Discussions 5 08-09-2013 09:22 PM
Bedliner tape on roof? Kanger328 3rd gen T4Rs 2 12-31-2012 12:36 PM
Paging Stick Figure, come in Stick Figure, do you read, over? riverrat44 3rd gen T4Rs 1 09-04-2008 11:53 PM
