Originally Posted by Boise Tim
Hello everyone I'm new here to the forum. Does anyone know where i can find a video or maintenance manual so I can swap out my T case and Just put in an OEM new used one? Trying to save some money. One mechanic here in Boise wants $4000 installed. I love my T4R but that's a lot of money.
Thanks.
I made a how to post here and it got included in the DIY fix it sticky. It also has a link to a How To video on YouTube:
5th Gen Transfer Case R&R and Seal Replacement
This year alone on my personal vehicles, I've completely rebuilt a NP 241 C and swapped that into a K2500 Suburban which had a leaking transfer case. My cost was $300 for parts and it was a couple hours to remove and another couple to install. The rebuild was simply replacing bearings, chain and seals. All the gears and shafts were fine. This actual rebuild took about 2 hours. Removal and install about 10 hours total, but nothing difficult.
I also pulled and replaced seals on the transfer case in our 2014 SR5. This one was even easier to pull than the one in the Suburban. Replaced output seal on transmission side and all the seals on the transfer case. This took less than an hour and the seals were about $30.
I'd like to thank those providing the cost quotes to do these jobs, which is in line with my estimates.
I also recently pulled and had the 5 spd manual transmission in my 2005 Honda Accord rebuilt. After replacing the clutch assembly, fly wheel and throwout bearing, it was still making a noise that would disappear when the clutch was depressed while in neutral. I knew then bearings were gone or going, which the transmission rebuild shop confirmed. I was able to pull the transmission in about 6 hours and reinstall in about the same time. Missed some football, but figured it was a $4K to $5+K job if someone else did it. Car runs and sounds like it did when new.
Why are you swapping out the transfer case? If it's just leaks, you're looking at $30 to $50 in parts. A rebuild kit would be <$300 and that would only take an hour or two. These are very simple to work on. The AWD units are a bit more complicated as they have clutch stacks in them. Before this year, I had never attempted this myself, now I would never consider not doing it myself.
