Old 04-29-2023, 06:58 PM #1
PK930's Avatar
PK930 PK930 is offline
PK930 will become famous soon enough
PK930's Avatar
ABS Issue
2012 SR5, 290,XXX on the clock
4wd and 4Lo blinking. Slip, ABS, and Brake light lit.
Carista scan shows faulty left rear sensor. Replaced sensor. Nothing. Replaced $100 wiring harness. Nothing.
Even did ZPC. Nothing.
I do need to do the rear bearings as the right is grinding and the left is showing some gear lube leakage. Could there be enough gear lube or other debris on the LH side to cause these faults?
Started acting up during a storm. ItÂ’s seen worse weather and never had an issue.
Thanks.
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 04-30-2023, 09:00 AM #2
spartacus's Avatar
spartacus's Avatar
Thanks.
The abs ring on the shafts if coverd with debris will cause the abs sensor to not detect the magnetic field and throw the code.
abs , gear , issue , replaced , sensor
4h to 4L issue coolkidd 4th Gen T4Rs 18 02-18-2019 03:00 PM
anyone else have or know of this issue?? waxyboarder09 4th Gen T4Rs 8 04-10-2015 11:37 AM
Oil issue mainzenblue General Discussions 1 12-05-2014 01:12 PM
tps issue need help!!! Akbeerun Classic T4Rs 18 02-15-2014 10:54 PM
AC Issue okccj Classic T4Rs 7 08-25-2010 11:09 PM
