Old 04-30-2023, 07:11 PM #1
MPow3r's Avatar
MPow3r MPow3r is offline
MPow3r is on a distinguished road
MPow3r's Avatar
Looking for some help on an oil leak
Hey guys/gals, looking for some help here. So, for my last oil change I changed out the filter housing to a metal one which is the only real thing that has changed and I watched it for a few days afterwards and no leaks. I glanced at some of my skid plates today and it looked like I had some oil on them. My first thought was that new housing but the leak seems to be coming from something higher. I am guessing this is the oil pump?
Has anyone seen this before? Could the new housing be causing an issue? I will probably take this to the dealer but just trying to do a bit of research first.
I have verified that it is not coming from anywhere around the top of the motor, it all seems to be clustered in that oil filter area but above the housing and seems to be pooling on some of the bolts picture below. Nothing has been done to the motor as far as repairs or modifications go.
Thanks!
Looking for some help on an oil leak-toyota1-jpg  Looking for some help on an oil leak-toyota2-jpg  Looking for some help on an oil leak-toyota3-jpg  Looking for some help on an oil leak-toyota4-jpg
MPow3r is offline   Reply With QuoteReply With Quote
Old 04-30-2023, 09:22 PM #2
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
Check your front main seal. I had to change mine and had leaking oil in the same general area.
Mack1611 is offline   Reply With QuoteReply With Quote
Old 04-30-2023, 10:26 PM #3
MPow3r's Avatar
MPow3r's Avatar
The more I research this, the more I think you are spot on... Thanks!!!
Old 05-01-2023, 12:52 AM #4
Jeremy556's Avatar
Jeremy556's Avatar
It's the gasket between the oil filter housing and oil pump. The airflow in that location blows the oil all over the place, even higher than where it leaks.
Did you replace the gasket when you replaced the oil filter housing? Check torque. Did you use Toyota parts? If still in doubt, swap parts back. Front main seal leak is highly unlikely. Last thing you touched is always most likely.
I had the same leak when I had to remove my oil filter housing to replace steering rack and tried to cheap out and not replace the gasket.
Old 05-01-2023, 06:10 AM #5
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
And just to confirm, have you tried reinstalling the original housing, in case there's a tiny flaw in the metal one?
Oops - Jeremy556 already said that.
thennen is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 10:55 AM #6
MPow3r's Avatar
MPow3r's Avatar
Yeah, this crossed my mind as well with how much airflow is in that location. Yes, I replaced the gasket but I did not use the OEM Toyota part on the housing (and I know better). I am due for another oil change so I am ordering those parts today. Thanks Jeremy!
Old 05-01-2023, 11:22 AM #7
Rocko9999 Rocko9999 is offline
Rocko9999 is on a distinguished road
How hard is that to change?
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 08:25 PM #8
Jeremy556's Avatar
Jeremy556's Avatar
3.5 book hours, mostly in remove/replace radiator.
I don't recall exactly how much room is there, but you may be able to get the crank pulley off without removing the rad, and if so, much easier job. Just remove the fan/shroud, oil cooler housing and crank pulley.
Old 05-15-2023, 08:07 PM #9
nevillemurillo nevillemurillo is offline
nevillemurillo is on a distinguished road
Did you replace the gasket when you replaced the oil filter housing? Check torque. Did you use Toyota parts? If still in doubt, swap parts back. Then you can be sure whether the part is defective or not. When a car is unsafe and the dealer attempts to repair it and the car is not repaired after a reasonable number of attempts, then it's a lemon and you can file a lawsuit. I don't know much about this but according to this page I don't think it's a lemon. See a lemon lawyer to be sure, maybe you can sue. Front main seal leak is highly unlikely. Last thing you touched is always most likely.
hello,
I am having the same leak. I didn't use Toyota parts because it was too expensive. Now I learned my lesson.
nevillemurillo is offline   Reply With QuoteReply With Quote
changed , coming , housing , motor , oil
**WATER LEAK** 4Runner Unusual Footwell Water Leak Solution chrisbagnell 4th Gen T4Rs 12 03-08-2022 11:58 PM
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Radiator leak, and oil leak maybe tranny? Not sure what should I do? ironmaidn23 Classic T4Rs 14 06-25-2013 10:34 AM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
