Old 05-04-2023, 04:07 PM #1
Roncu Roncu is offline
Roncu is on a distinguished road
Brake pad wear
I have a 2016 trail premium with 47000mi. I bought it new and it still has the original brake pads. Checked the pads prior to inspection and they measure 6mm front and 2mm rear. Seems a bit odd, or is the normal?
Roncu is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 08:27 PM #2
djeepin djeepin is offline
djeepin is on a distinguished road
normal. keep stock brakes equipment, clean frequently to prevent seize. you may not know, but T4R using rear brakes more than front. and you are normal driver, no acceleration between red lights, and good distance to the vehicle front of you.
djeepin is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 09:06 PM #3
Thanks for the info. 72 years and I always experienced almost 2 to 1 front wear to rear because of weight transfer. I learned something today.
Old 05-04-2023, 09:21 PM #4
Figure11 Figure11 is offline
Figure11 is on a distinguished road
Normal for sure. Side-note, I wish my '16 had <50k on it.
Sent from my SM-N986U using Tapatalk
Figure11 is offline   Reply With QuoteReply With Quote
Old 05-06-2023, 01:10 PM #5
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Normal on modern vehicles. Old school had fixed pressure split of ~70/30 Front/Rear and would typically see Fronts wear out first. This is because you have more force on the front under braking and so more available traction, you don't want to overdrive the rears causing traction loss and unintended oversteer.
Modern braking systems can modulate pressure front/rear and left/right and under normal/moderate braking it is beneficial to send more to the rear to reduce dive and maintain vehicle composure, but not so much to cause slip.
Oldschool = fixed
Newschool = variable - which enables better braking strategies
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 05-07-2023, 04:28 PM #6
Glenn Goodlett's Avatar
Glenn Goodlett Glenn Goodlett is offline
Glenn Goodlett will become famous soon enough
I have 80K on my 2020 and still quite a bit of pad left on the front and back.
2020 Army Green TRD Pro
2007 FJ
Glenn Goodlett is offline   Reply With QuoteReply With Quote
Old 05-08-2023, 08:21 AM #7
tgn225 tgn225 is offline
tgn225 is on a distinguished road
I’ve noticed the same wear pattern on mine. That’s good to know that it’s normal
tgn225 is offline   Reply With QuoteReply With Quote
Old 05-09-2023, 05:04 PM #8
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
I did not want to believe rears wear faster so gathered some empirical data. I did rotors and pads at 75k and just did pads yesterday at 150k all OEM and my results / photos are below.
All rears wore very evenly down to ~0.35"
Passenger Fronts worn down to .42, Driver front had uneven wear between pads, inside (.35) and outside (.44). Inside pad with wear indicator was squeaking at this thickness.
At least in my case rears wore faster. I confirmed both sets start out with 11.5 mm. My measurements include the backing plate thickness which is the same for fronts and rears.
Not sure why my driver front wore unevenly. Rotors seem square, clean and in good shape. Was able to move pistons back into calipers with relative ease and sliding pins were fine. Will check back in after another 75k I guess.
Brake pad wear-img_2987-jpg  Brake pad wear-img_2988-jpg  Brake pad wear-img_2989-jpg  Brake pad wear-img_2990-jpg  Brake pad wear-img_2991-jpg  Brake pad wear-img_2992-jpg  Brake pad wear-img_2993-jpg  Brake pad wear-img_2994-jpg
El Dusty is offline   Reply With QuoteReply With Quote
Old 05-10-2023, 06:12 PM #9
The delta on your driver front may suggest seized/sticky piston.
Old 05-12-2023, 02:47 PM #10
brevard2012 brevard2012 is offline
brevard2012 is on a distinguished road
the rear pads are smaller than front pads,
so to me, the even wear rate front and back doesn't mean rear brakes are working harder than front.
brevard2012 is offline   Reply With QuoteReply With Quote
Old 05-12-2023, 08:57 PM #11
I would never see 80,000 miles on brakes. I'm a sensible driver but it is all stop and go. Very little highway.
bit , brake , odd , pads , rear
Uneven brake wear - Help please stonnie Maintenance/Detailing 6 04-20-2021 06:15 PM
Uneven Brake Pad Wear Veritas 4th Gen T4Rs 9 08-04-2020 09:18 PM
Brake Wear sport2004 4th Gen T4Rs 5 08-30-2017 03:19 PM
Brake Wear claydoctor 4th Gen T4Rs 4 04-30-2014 11:15 PM
Brake Pad Wear... jstutz101 4th Gen T4Rs 4 06-07-2012 06:48 AM
