Old 05-18-2023, 02:00 PM #1
heard4it heard4it is offline
heard4it is on a distinguished road
replacing valve cover gaskets
Hello all, new to the forum and to 4runners. I recently traded in my Tacoma for a 2010 4runner w/ 211,000 miles. I changed the spark plugs this week and noticed oil accumulation in several of the spark plug holes. No signs of oil burning or head gasket leakage from what I can tell. I'm led to believe a valve cover gasket and spark plug gasket job is in order. Before diving in and ordering parts, I just wanted to confirm the part numbers I have here are correct. Also, are there any other parts or tools I would need or recommended for this job beyond basic hand tools. Any sealant needed around the valve cover gasket when replacing? Here is the list I have so far (my main point of concern was if the intake manifold gasket was the correct one as there were a few in the parts fiche to select from). I'm also planning to replace the PCV valve as a preventative measure. thanks in advance
11193-70010 x 6 (plug tube seal)
11214-31030 x 1 (valve cover gasket)
11213-0P010 X 1 (valve cover gasket)
17176-31140 x 1 (intake manifold gasket)
heard4it is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 02:52 PM #2
Whippersnapper02's Avatar
Keep in mind that the dual VVT-i 1GR has the VVT oil supply going through the valve cover unlike the single VVT-i so you may need the crush washers for the banjo bolts.
Old 05-18-2023, 03:14 PM #3
Good point! Thanks
Old 05-18-2023, 03:30 PM #4
Good point! Thanks
Here’s a teardown of a similar but not exact 2GR.
Toyota Lexus 2GR-FE Teardown! Premature Death Of Toyota's Most Reliable V6 Caused By Obliviousness! - YouTube
Old 05-18-2023, 11:08 PM #5
Forgetful Forgetful is offline
Forgetful will become famous soon enough Forgetful will become famous soon enough
Good luck with the job! In a sick way I love these kinds of projects.
Forgetful is offline   Reply With QuoteReply With Quote
Old 05-19-2023, 12:06 AM #6
DougR's Avatar
DougR DougR is offline
DougR is a jewel in the rough DougR is a jewel in the rough DougR is a jewel in the rough DougR is a jewel in the rough
DougR's Avatar
Valve Cover Gasket Replacement Videos
4 Videos by Usman the Mechanic
includes tips on removing connectors and tools to use.
5th Gen Toyota 4Runner 4.0l: detailed valve cover gasket replacement (LH) - YouTube
5th Gen Toyota 4Runner 4.0l: Detailed Valve cover gasket replacement part 2 - YouTube
5th Gen Toyota 4runner 4.0L: Detailed valve cover gasket replacement part3 - YouTube
5th Gen Toyota 4Runner 4.0l: Detailed Valve cover gasket replacement part4 - YouTube
Video by David Gatto
5th Gen 2010-2021 4Runner Valve Cover Gasket Replacement - YouTube
DougR is offline   Reply With QuoteReply With Quote
Old 05-19-2023, 09:15 AM #7
Humble Leader's Avatar
Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all
the first 3 part numbers are what were used to replace mine and spark plug o ring seals. I did not require the intake manifold gasket to be replaced so I don't have that part for reference
In addition, 18 sealing washers were used 90210-06013 and I did the camshaft gasket at the same time
camshaft: 11159-0P010 x 4 and 90430-10024 x 2. I had this done at the dealer
Old 05-19-2023, 09:50 AM #8
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
Here’s what you need to replace
replacing valve cover gaskets-img_3432-jpg
A Guy A Girl and A Trail
instagram.com/aguyagirlandatrail
www.aguyagirlandatrail.com
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 05-19-2023, 02:22 PM #9
very cool video!
Old 05-19-2023, 02:23 PM #10
thanks, I've watched these!
Old 05-19-2023, 02:24 PM #11
thanks, do you remember if any sealant was used on the valve cover gaskets?
Old 05-19-2023, 02:27 PM #12
thanks, are the small orings circled in green part of the oil return system? Is that a possible source of leakage as well?
Old 05-19-2023, 03:09 PM #13
I am actually not sure if sealant was used. I don't believe it is required but the toyota FIPG or an RTV would work. the fipg will work both as an adhesive and sealant
cover , gasket , parts , spark , valve
Best Valve Cover Gaskets 3.4L? BoomerBob 3rd gen T4Rs 48 05-07-2023 12:16 PM
Replacing Valve Cover Gaskets - A True Write Up - **PICTURES** ramonortiz55 3rd gen T4Rs 207 01-08-2023 11:08 PM
Any other gaskets I should replace when doing to valve cover gaskets? michaelreed 4th Gen T4Rs 0 07-23-2013 09:08 AM
Valve Cover Gaskets 4RUN0326 3rd gen T4Rs 6 04-22-2013 02:32 PM
po325 code after replacing valve cover gaskets hmbrews 3rd gen T4Rs 1 02-02-2010 05:08 PM
