Originally Posted by BlueRunner428
So I have been searching the Internet, but can't find a definitive answer to this. Basically, my understanding of the transfer case is that 4Hi locks in the front driveshaft so both differentials get power but otherwise the drive train stays the same. Whereas with 4Lo, it engages a sort of mini-transmission within the transfer case that takes the load off of the transmission and torque converter for hardcore off road situations where lots of torque is constantly needed that could otherwise start to over strain the transmission and torque converter.
Now when in 4Lo, you can only go up to about 15 or 20 mph before starting to get into really high RPMs. There are no higher gears to shift into. So my question is, is the regular transmission still engaged but just staying in one gear and operating through the transfer case or has it been disengaged entirely? I would imagine the torque converter is still engaged because otherwise the engine would stall out when stopped.
Uh
Power still passes right through the transmission and its gears in 4Lo. After the transmission, 4Lo engages a reduction ratio in the transfer case before it sends power to both driveshafts. The low range reduction ratio is 2.57 to 1. So divide all your forward gears by 2.57 and that's how short they are in low range. Flipped on its head, the low range gears are 39% as tall as the high range gears. I can't remember if low range will automatically engage 5th gear (overdrive) or not, someone else can answer that.
With the low range gears this short, the torque converter doesn't have to slip near as much at low speed, which helps lessen overheating. I have seen plenty of people overheat automatic transmissions offroad by trying to keep it in 4Hi on the really slow and hard stuff.
