Old 05-20-2023, 11:45 AM #1
Coyotegray's Avatar
Coyotegray Coyotegray is offline
Coyotegray will become famous soon enough
Coyotegray's Avatar
Drilled/Slotted Brake Rotors
For my next brake service Im considering a kit that includes Drilled/Slotted Brake Rotors.
Has anyone seen any problems with this driving offroad in mud, etc..?
2017 Toyota 4Runner TRD Off-Road Premium, Dual Battery with Blue Sea Switch, 2" Lift with Eibach Coilovers & ICON 2" Rear Springs, GOBI Stealth Cargo Rack, BFgoodrick KO2 Tires, weBoost Drive 4G-X OTR 470210 Cell Phone Signal Booster, Goose Gear Rear Plate, ARB CKMTA12 On-Board Twin Air Compressor, ARB Differential Breather Kit, Yaesu FT-891 & ICOM IC-2730A Amateur Radio Transceivers, Victory 4X4 Blitz Bumper and HF APEX 12,000 lb Winch.
Coyotegray is offline   Reply With QuoteReply With Quote
Old 05-20-2023, 12:56 PM #2
Matt831 Matt831 is offline
Matt831 will become famous soon enough
I would never put them on a vehicle that sees off road duty. Do some searching and you will see mostly negative comments when you mix off road and drilled/slotted rotors.
If you want more stopping power, you need bigger brakes but the brakes on the 4Runner are pretty good in my opinion.
Matt831 is offline   Reply With QuoteReply With Quote
Old 05-20-2023, 01:02 PM #3
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
No real reason to bother. It's not a sports car. And yeah those plus off road aren't the best combo either.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 05-20-2023, 01:45 PM #4
stiles_s stiles_s is offline
stiles_s will become famous soon enough stiles_s will become famous soon enough
Even on sports cars the benefits are debatable and it introduces risks of cracking, breakage, etc. also think about the smaller pad surface contact patch you create. Imo I would stay away.
'22 4runner Limited (ORP 17s)
'18 MacanS (wife's)
'10 997S
stiles_s is offline   Reply With QuoteReply With Quote
Old 05-21-2023, 03:41 PM #5
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
some centric drilled/slotted brake rotors are on my mind when it comes time to replace my OEM rotors.
I had to panic stop on the freeway from 70 to 0 due to stop traffic coming off a blind offramp that went under a overpass. I blew threw the brakes and the brake petal sunk to the floor and had to swerve on to the shoulder to stop. This definitely got my attention.
Yeah, i drive on the road 90 percent of the time and probably if I"m lucky, i get to offroad 10 percent of the time, so slotted/drilled brake rotors make sense to me.
Old 05-21-2023, 07:45 PM #6
Whippersnapper02's Avatar
Only slotted if you must but OEM stops well and slotted isn’t going to make it much better if at all.
Old 05-23-2023, 12:00 AM #7
get the rotors turned and throw some akebono pads on. It's fantastic. I warped my rotors but i didnt get them turned when i swapped pads. and i'm also taking it alot easier on the brakes this time around when we're offroading.
Old 05-23-2023, 12:05 AM #8
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
Tires matter more if you’re truly concerned for shorter braking distances
1jzgte is offline   Reply With QuoteReply With Quote
Old 05-23-2023, 09:24 AM #9
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
Raybestos or AC Delco High Performance Slotted rotors are all I use. Unlike the OEM, have not warped these yet and we have 330K miles on the truck and do plenty of off-roading.
2014 TOYOTA 4RUNNER 4.0L V6 Rotor | RockAuto
Drilled/Slotted Brake Rotors-img_3945-jpg
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 05-23-2023, 03:29 PM #10
Love that those are working for you. That's what matters.
As far as slotting (or S-grooves ), the *theory* is that they help pad gasses dissipate faster. The reality is I've never seen a conclusive test. What they certainly *do* do is reduce the surface area the Pad gets to bite into and therefore increase the wear speed of the rotor because for the same stopping "friction" you are operating on a smaller rotor surface area. As far as warping, 99% of the time this is from uneven pad deposits on hot rotors and not physical rotor deformity. Again from a logic POV not sure how slotting is going to help here. If anything, removing Rotor material makes it less able to absorb heat so the rotor will heat up *more* than non-slotted for a given braking activity (say a 60mph to zero abs limited stop)
IMHO it's a gimmick folks use to charge more money for rotors. Yes, I've used a bunch of combinations. Slotted, drilled, etc. Back in my heavy Audi/VW/BMW tuning days.
Our 911 has drilled rotors from the factory. Even here I think it's mostly about looks though Porsche engineered the braking such that they accounted for the reduced surface area of the drilled rotor.
OK, I've nerded out more than I should have...
'18 MacanS (wife's)
'10 997S
Old 05-23-2023, 05:53 PM #11
Well my unscientific testing has proven otherwise on several vehicle types: Suburban K2500, 4Runner, Honda Accord. In each case warping or brake pad deposits (cementite) has been eliminated and that includes a huge amount of mountain driving in CA with climbs/descents over 8,000’. The Honda OEM rear rotors cracked. No difference in brake pad life on any of the vehicles. The literature says this is possible on cheaper, poorly machined rotors as they can shave off brake pad material. I’m getting 80K to 90K on 4Runner pads in the front. All the literature and science says slotteds run cooler and if they run cooler there is less of a chance that you harden an area of the rotor which creates your “warp.”
One thing I will acknowledge, there is no discernable or observable difference in breaking distance.
P.S. Your so-called Porsche Macan runs a 2.0 liter Audi engine.
Old 05-23-2023, 07:43 PM #12
As I said above, super happy the slotted rotors are working for you. I'd love to see the literature and science you point to. Is the science related to slotted rotors or ventilated?
I'm just happy that rotors seem to warp less on the 5th gen 4R than they did on my old '07 GX470. I looked at it wrong and they warped.
Sick burn re: the Macan, but:
- I was talking about the 911 and
- Our Macan has the 3.0tt v6 from the Panamera, not the later ones which switched to Audi/VW sourced engines. Happy to go down the rabbit hole with you on this. BTW, yes, it's a glorified Audi Q5. Yes, it's way better to drive than the comparable Audi Sq5 (btdt). Oh, and is doesn't have drilled or slotted rotors. It's my wife's and she gets what she wants, And... I doubt you actually wanted to learn more about the Macan
'18 MacanS (wife's)
'10 997S
Old 05-23-2023, 10:07 PM #13
In the spirit of learning: Drilled, Slotted & Vented Brake Rotors - What's Best? - YouTube
I am a big fan of this guy’s videos. Looks like I was a bit too hard on slotted.
'18 MacanS (wife's)
'10 997S
Old 05-24-2023, 12:35 PM #14
Looked at this video, he was critical of drilled. Not so much critical on slotted.
Looked at another video where the guy did tests on a non-abs car with OEM vented then slotted with peformance pads and the latter had superior stopping distance, especially after they were heated up.
All the literature says track racers use slotted as they are superior in dissipating heat. I went to slotted after my wife kept “warping” rotors. It was due to heat. Two scenarios: 1) heavy stops in SoCal traffic, followed by standing on the brakes while stopped at a light, thus creating a hardened spot of cementite; and 2) heavy braking coming down from a home we have on Big Bear Lake which has an altitude drop of 7,000’. Given those, I switched to the Raybestos or AC Delco (same manufacturer) slotted and no more issues. Could be due to the superior material and casting process. They do have the same rotors in plain vented.
We put tons of miles on our cars with a lot of moutain driving. I do all the work on our cars, so I’m going to use what works as I hate re-work because it cuts into my play time (fishing).
P.S. always wanted a 911 when growing up. Closet I got were VW Bugs. Wife had a SLK 280 w/ 6 speed manual. It was fun. I was German. It was impractical. All we want now are functional truck style (not crossover) SUVs. No fancy off-road suspensions, but very functional true 4WD SUVs.
Old 05-24-2023, 12:45 PM #15
Genuinely curious about 2 things, and thanks for sharing your experience:
1) Did you try the new pads with new non-slotted rotors? Or, did you change both?
2) I'd appreciate pointers to the literature you're referring to. I still don't understand how slotted rotors could be superior to standard at dissipating heat as they have slightly less mass.
3) I do buy that slotted might help reduce buildup for the reasons "engineering explained" noted regarding slots "scrubbing" the pads resulting in a) faster pad wear but perhaps b) the scrubbing helps with overheated pad-transfer to the rotor.
Regardless, truly appreciate your BTDT experience.
'18 MacanS (wife's)
'10 997S
brake , drilled/slotted , mud , offroad , rotors
Drilled, Slotted & Vented Brake Rotors - What's Best? ghs215 4th Gen T4Rs 2 09-02-2015 01:05 AM
Slotted drilled rotors gigerunner Classic T4Rs 0 12-11-2013 02:52 PM
4Runner DRILLED SLOTTED BRAKE ROTORS Toyotero4ever Problems & Warranty Issues 6 04-09-2013 09:43 AM
upgraded to drilled / slotted rotors ? 4RNNR Engines / Suspension / Wheels / Tires / Audio / Accessories 11 03-16-2011 09:41 PM
cross drilled,slotted rotors Quint 4th Gen T4Rs 9 05-26-2009 01:58 PM
