Old 05-26-2023, 02:50 PM #1
Rocko9999 Rocko9999 is offline
Rocko9999 is on a distinguished road
2011-Startup Noise
Can someone tell me what the start up noise-coming from near the dash- is on my Limited? Sounds like an electronic brake being released-like an actuator. Is it tied to the push button start?
Just before the engine starts. Imgur: The magic of the Internet
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 05-26-2023, 03:08 PM #2
Humble Leader's Avatar
does it change based on what your HVAC controls are set to? my initial thoughts are brake booster, power steering pump or HVAC. power steering and brake booster are right behind the firewall on driver's side
I have a 2012 limited. I can go check if mine makes that sound too. I feel like it does but never really thought much of it
Old 05-26-2023, 04:45 PM #3
Same sound regardless of hvac. Maybe some automatic brake applying actuation for push start? Not sure.
Old 05-26-2023, 06:56 PM #4
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Turn on your A/C on and let it run for a few seconds as you cycle through each of the hvac zones (Defrost, feet, head etc.) If you hear that sound or similar repeating it may be a bad blend door.
I have heard similar sounds with a friend's vehicle that had a damaged gear on the blend door. The blend door motor, sensors and Hvac system were not happy and the zones did not cycle through correctly on the passenger side of the vehicle.
I could be totally wrong. Just a hunch.
El Dusty is offline   Reply With QuoteReply With Quote
Old 05-28-2023, 01:24 PM #5
Sonoran_Desert Sonoran_Desert is offline
Real Name: Jo
Sonoran_Desert will become famous soon enough
Real Name: Jo
Turn on ignition to first position (but do not turn 2nd time to start engine) and press on the brake pedal. Do you hear a variation in the noise?
\\02 Hydraulic brake booster faliure
Sonoran_Desert is offline   Reply With QuoteReply With Quote
2011-startup , actuator , brake , released-like , start
Grinding noise on startup jpeaslee 3rd gen T4Rs 10 06-10-2022 08:51 AM
2011 Toyota Sienna van smokes on startup (sludge?) wanderingandrew Off Topic 7 11-17-2017 12:42 AM
Strange noise on startup samdajellybeenie14 3rd gen T4Rs 6 10-24-2013 02:39 PM
Noise From A/C On Startup ohuett 4th Gen T4Rs 14 11-21-2012 12:58 PM
screeeetch noise on startup maximilian 3rd gen T4Rs 6 10-08-2007 10:31 PM
