Old 05-27-2023, 12:31 PM #1
4RL75 4RL75 is offline
4RL75 is on a distinguished road
Use of "High beam" on 2023 Limited
Several months ago I purchased a 2023 Limited, it has the LED headlamps with projectors so low and hi beams are controlled by the projectors. It still has the high beam reflector with the 9005 halogen bulb but it doesn´t light up. Of course it has the bulb and it´s wired. I tried to find a custom setting maybe for a daytime running light, don´t have that, Even using techstream, don´t have the option. Also tried Carista, no luck.
Any inputs?
4RL75 is offline   Reply With QuoteReply With Quote
Old 05-27-2023, 02:23 PM #2
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
You’re trying to use your DRL as another high beam? The reflector changed so it doesn’t give the same pattern as previous years. You’ll have to add a relay and custom wiring to get it to work the way it sounds like you want
NB17Limited is offline   Reply With QuoteReply With Quote
Old 05-27-2023, 10:51 PM #3
Actually in my truck it has no use. I don't have DRL nor high beams on the reflector. My question may not make much sense, I just noticed the reflector, the bulb and the wiring but not use for it. If I could add a relay and make the DRL would be great.
Old 05-28-2023, 07:38 AM #4
It does have a use. It’s your DRL. If you leave your stalk on auto, that reflector will be on after you take your parking brake off and start moving. If you have the stalk on another setting, then it potentially will look like the reflector does nothing
Old 05-29-2023, 11:32 AM #5
Thanks, I will check that!
Old 05-31-2023, 11:15 AM #6
lewis26 lewis26 is offline
lewis26 is on a distinguished road
DRL's are enabled in the vehicle settings section of the head unit.
lewis26 is offline   Reply With QuoteReply With Quote
Old 06-01-2023, 11:54 AM #7
kmeeg's Avatar
kmeeg kmeeg is offline
kmeeg is on a distinguished road
kmeeg's Avatar
My Quad Highbeam Setup
That 9005 bulb in the reflector is DRL only.
I was in the same situation with my 2021 TRD Pro. I added a relay harness just like wiring a light bar and use the bulb in reflector as second set of highbeams.
Here's the video explaining what I did. There's another video I added 2 light bars to the same wire and there will be a future video adding 2 spot lights to the same wiring for even more light.
https://www.youtube.com/watch?v=vesGHtosIHk&feature=youtu.be
KMeeg.
www.youtube.com/LionRunner
(Mods and how to videos for 4Runner SR5, TRD ORP wo/KDSS, TRD ORP w/KDSS, Limited, TRD Pro.)
kmeeg is offline   Reply With QuoteReply With Quote
bulb , don´t , high , light , projectors
'22 Toyota OEM "High Performance Fog Lamps" vs "standard" LEDs RobS10 5th gen T4Rs 10 03-13-2022 09:18 AM
Differences between "2009 limited" or "2010 sr5" longeuayms General Discussions 7 01-30-2014 10:16 AM
12 Limited to High to get in and out of 20" Dunk50 5th gen T4Rs 26 01-01-2013 10:21 AM
WTB: 4th Gen "4Runner," "Limited," and "Toyota" badges James_T Want to Buy/Trade 3 06-25-2011 11:42 AM
2011 Limited Fog Lamp Turn Off With High Beam LTDPearl 5th gen T4Rs 12 02-19-2011 07:34 PM
