Old 05-30-2023, 01:56 PM #1
Rocko9999 Rocko9999 is offline
Rocko9999 is on a distinguished road
Oil Leak-How Worried Should I Be?
2011 Limited. I have a couple of oil leaks that come from the part between the head and valve cover-not sure the name. First pic is rear passenger side. Second is front driver side of engine. How worried should I be?
Imgur: The magic of the Internet
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 05-31-2023, 09:15 AM #2
Humble Leader's Avatar
Humble Leader Humble Leader is online now
looks like valve cover gaskets need to be replaced. valve covers only leak (I believe) when the engine is on and when oil is moving around so you likely won't notice any drips. I had the dealer do mine with the spark plug gaskets and cam shaft seals as well. might as well do them all at the same time
in terms of worried - it doesn't look like you've lost enough oil to be causing engine damage. but still fix it
Humble Leader is online now   Reply With QuoteReply With Quote
Old 05-31-2023, 09:39 AM #3
Forgetful Forgetful is offline
Forgetful will become famous soon enough Forgetful will become famous soon enough
Meh, see if you can snug up the bolts.
Forgetful is offline   Reply With QuoteReply With Quote
Old 05-31-2023, 01:04 PM #4
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Have you cleaned it in 12 years?
I get a very small amount that collects there on the driver’s side. I clean every couple of years. It might look like yours if I never cleaned it.
1000MPH is offline   Reply With QuoteReply With Quote
Old 05-31-2023, 06:52 PM #5
I don't think it's ever been cleaned. I will wash it off and monitor.
Old 05-31-2023, 06:53 PM #6
Valve cover is actually above the leak. This is cam tower from what I have read. Not an easy fix.
Old 05-31-2023, 07:03 PM #7
album , engine , oil , side , worried
Oil leak on engine near dip stick, should I be worried? Ron_Mexico 4th Gen T4Rs 10 01-19-2023 04:26 PM
so now I'm getting worried. rick1987 4th Gen T4Rs 3 08-18-2015 08:36 PM
Anything to be worried about? nc-grayson All Other Vehicles 0 04-23-2015 10:07 AM
I'm getting very worried about the 5th gen GatorGreg 5th gen T4Rs 44 12-09-2008 06:16 PM
should I be worried? ozana 3rd gen T4Rs 21 09-15-2008 03:42 PM
