Old 06-05-2023, 08:12 PM #16
djeepin djeepin is offline
djeepin is on a distinguished road
someone may notice that Toyota vehicles all over the word: Asia, Africa, Middle East, etc. - in all poor countries you find Toyotas, working hard, with low maintenance, poor lubricants, unskilled mechanics - but it works! Kudos to Japanese ingenuity! Good we have a choice. For now.
djeepin is offline   Reply With QuoteReply With Quote
Old 06-08-2023, 05:54 PM #17
Pepperhead71 Pepperhead71 is offline
Pepperhead71 is on a distinguished road
Check out The Car Care Nut channel on YouTube.He's a Toyota Master Technician has a great video about when and if you should change your transmission fluid.
Pepperhead71 is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 12:00 PM #18
EastTXHick EastTXHick is offline
EastTXHick is on a distinguished road
I do realize this is an old thread but, did want to give my real world experience with Tranny fluid changes. I purchased my 05 Runner in 2014 at 89K and drove way beyond the recommended mileage, as in 133K. Mind you tranny was never serviced prior to. Like most folks, I scoured the internet for sage advice and found both the oem and aftermarket camps were very stongly opinionated. So... I decided to use the Maxlife and do a drain/fill. I then repeated at 150K. I can say 100% percent there has been no shifting issues what so ever. I would think that after 20K miles and 3 years something would occur that I had caused by not using oem fluid? I am by no means a technician, just a middle aged dude that prefers to do his own maintenance to ensure quality is performed and I am also a cheap bastard as well. Hope this helps the undecided camp in the future
EastTXHick is offline   Reply With QuoteReply With Quote
Old 02-22-2024, 03:31 PM #19
dexter80 dexter80 is offline
dexter80 is on a distinguished road
Same here. Bought ‘12 Limited with 75k miles, light towing of a 10’ Haulmark a few times a year.
One day while doing an oil change I accidentally drained ATF. Oops. So I did an unplanned ATF change at around 110k miles. Most fun part was not knowing how much fluid I drained. Took a few days due to exceptionally hot Oct North Tx Temps in 100s.
Car ran as fine after the change as before. Used Toyota brand fluid from dealership, they matched an online price.
2012 4Runner Limited 4WD
dexter80 is offline   Reply With QuoteReply With Quote
Old 02-22-2024, 04:49 PM #20
Nepatie Nepatie is offline
Nepatie is on a distinguished road
Hello Bassman,
While it's true that regular maintenance, including changing the transmission oil, is essential for the longevity of your vehicle, there isn't a hard and fast rule about never changing the oil past a certain mileage without having done so earlier. The 60k recommendation is a general guideline suggested by manufacturers to ensure optimal performance and longevity of the transmission. However, if you've missed that interval, it's still advisable to change the transmission oil to prevent potential damage and maintain the health of your vehicle.
Changing the transmission oil at 90k miles would still be beneficial and shouldn't cause additional harm to your vehicle. In fact, neglecting to change the oil could potentially lead to more significant issues down the line. It's always best to consult with a trusted mechanic or refer to your vehicle's owner's manual for specific maintenance recommendations tailored to your make and model.
Nepatie is offline   Reply With QuoteReply With Quote
Old 02-24-2024, 03:14 PM #21
Getrigged Getrigged is offline
Getrigged is on a distinguished road
I did mine around 100'000 miles, used valvoline. my research led me to believe the transmission fluid needs a bit of the ultra-fine impurities for proper shifting, so i opted to essentially, change the filter and dilute the ATF since a lot of the fluid stay in the gearbox not the tray. A flush seemed more likely to cause issues.
Further down the road ~120'000 miles i installed a tranny fluid cooler so again drained the pan and added new after the cooler was in so again diluted it.
Getrigged is offline   Reply With QuoteReply With Quote
Old 02-24-2024, 05:07 PM #22
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
It’s a wive’s tale that the transmission needs wear material for proper shifting, otherwise they would not shift properly from the dealership.
In most cases where people experience transmission failure shortly after flushing the fluid, the damage was already done before the flush. Just had a friend who had this happen. 225K on a Highlander, never changed the fluid. Transmission started having issues, so he took it to a dealer for a power flush and it started stuttering at highway speed shortly afterwards. It’s done and 225K is good amount of mileage for never changing the fluid. Say hello to a $5K to $6K transmission change.
CutthroatSlam is offline   Reply With QuoteReply With Quote
60k , change , damage , oil , transmission
Should I Change My Transmission Fluid? Berty_K 4th Gen T4Rs 42 07-30-2022 08:25 PM
Should I change transmission fluid or not? bgravy 3rd gen T4Rs 34 04-11-2020 02:12 PM
Transmission Fluid Change Flifisher 3rd gen T4Rs 77 12-27-2017 10:58 AM
Transmission Fluid Change? chetJ 5th gen T4Rs 8 05-06-2014 08:22 AM
Transmission oil change on 97Rnnr 2WD jim77446 3rd gen T4Rs 8 08-19-2009 10:55 AM
