Old 06-10-2023, 08:36 PM #1
SgtKeebler SgtKeebler is offline
SgtKeebler is on a distinguished road
ABS, Trac Control, & Brake dash light
With the car is in park, in either in accessory mode or running, when I pump the brakes 4-6 times the ABS, traction control and parking brake dash lights turn on as well as makes a beeping sound. It only lasts for a few seconds then goes away.
I have recently changed all 4 brake pads and brake fluid. When driving around I don’t get any warning lights and brakes are responsive and don’t have any braking/stopping issues. Tested 30-0, 40-0, 50-0 and 60-0 all without any issues.
Any ideas what might cause the warning lights to come on when pumping the brakes in park?
SgtKeebler is offline   Reply With QuoteReply With Quote
Old 06-11-2023, 12:51 AM #2
Jeremy556's Avatar
Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold
Jeremy556's Avatar
What's the stored code? How exactly, did you go about changing the brake fluid? If you introduced air into the master cylinder, you'll need techstream or similar scan tool to bleed it.
Old 06-11-2023, 03:47 PM #3
Not getting any codes on code reader. Ran it numerous times, still no codes. Even had code reader going when I caused the issues still nothing.
I kept the tank for master cylinder full, never dropped below the minimum line and used a bleeder bottle with brake fluid in it so that the discharge hose end wouldn’t suck in any air.
abs , brake , brakes , issues , lights
Parking Brake/ABS/TRAC Dash Lights On bspurs 4th Gen T4Rs 6 07-03-2022 02:06 AM
No trac off or vsc light on dash jiggajatt 4th Gen T4Rs 3 04-30-2017 04:44 PM
VSA/ Trac control/engine light on poikilotrm 3rd gen T4Rs 4 11-03-2013 11:19 PM
VSC TRAC light on, traction control issues? Skips in acceleration Dext77 4th Gen T4Rs 2 10-31-2013 01:26 AM
Need Help Brake VSC TRAC light on Jorge328i 4th Gen T4Rs 0 10-09-2012 12:18 AM
