12-26-2023, 05:25 PM
#16
Power Steering Fluid is simply ATF without the red dye.
12-26-2023, 07:37 PM
#17
I use atf most of the time as I usually have plenty of that. Otherwise swepco 715 if I specifically need PS fluid.
05-29-2024, 02:29 PM
#18
Did you change your Ps fluid with Amsoil OE or the signature 100% synthetic one? how long did you do it? how does the PS been working?
05-31-2024, 10:51 PM
#19
I only use Idemitsu Bukaki power steering fluid. Never have any circle jerks in 4wd on dry pavement.
06-07-2024, 11:33 PM
#20
Looks like NAPA has the Idemitsu PSF for a more reasonable price than Amazon if anyone is interested.
Just a moment...
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
06-19-2024, 04:23 PM
#21
Originally Posted by message
Maybe I'm the only one doing this, but I thought it was common knowledge?
You can flush the PS fluid by simply jacking the front tires off the ground, removing the PS return line, and turning the wheel clock to clock with the engine off and the key in the on position.
To prevent a mess I plug the return port on the reservoir and extend the return line into a bucket on the floor. As soon as the reservoir is almost empty and before it can suck air, I fill it to the top with new fluid.
Repeat the process a few times until the fluid running out is clear.
No turkey basters, no partial fill, and easy clean exchange of all PS fluid.
I did the same method in 2011 on my 3rd gen. Check my photos. Works like a charm.
MH-139A Grey Wolf Mechanic.
06-25-2024, 09:21 AM
#22
Anyone having heavy steering wheel? I changed the oil using the baster method over several days but it did not help. I'm running 285s since new. I cannot tell at which point the steering became heavy.
06-25-2024, 06:52 PM
#23
Only after driving other cars with light steering.
08-16-2024, 08:08 AM
#24
No lift front end, don’t have jack stands.
If I do all the steps but just leave the front end on the ground instead of lifting it up, will there be any negative consequences.?
08-16-2024, 09:06 AM
#25
No, it will just make turning the wheels harder and scrub the tires.
4th Gen Toyota 4Runner Power Steering Fluid Exchange Service
08-16-2024, 09:50 AM
#26
I do mine with all the other fluids at 50k. Easy to remember that way. I use Lubegard 23232 power steering fluid. I use a fluid extractor on the return line. No mess at all. I also install an inline filter.
08-16-2024, 03:31 PM
#27
J.A., Thanks
08-16-2024, 09:27 PM
#28
Be careful when pulling the return line, the plastic reservoir can get brittle as it gets old.
09-14-2024, 01:44 AM
#29
I just did mine at 187k. It was dirty. Refilled with Valvoline transmission oil I had left over. Works fine.
2016 QUICKSAND TRD PRO,Rear diff breather mod, Salex organizers, Huskyliners, CBI sliders, RCI TRD intermediate skid plate, RCI aluminum transmission skid plate, RCI STEEL transfer case skid, RCI Aluminum fuel skid and A arm skid. RagoFab modular storage panel. King extended travel front and rear with compression adjusters. 2" Toytec superflex rear springs. C4fab front bumper, Ngyuenworks high clearance rear bumper, Baja design light bar S2 rear lights.
09-14-2024, 05:29 PM
#30
3rd Gen translates to 5th gen?
Hey all, I replaced the fluid on my 3rd gen in 2011. It was a '97 with the 3RZ-FE 2.7-liter 4-banger. I used pennzoil atf and it worked great. I did lift the front end off the road surface, turned the key on to the 'unlock' setting and just rotated the wheel side-to-side and made sure there was enough fluid in the reservoir. I removed the return line off of the metal reservoir and made sure to point it down towards the ground where the drip pan was. I capped the return nipple for this process. All the new fluid pushed out the old. When I saw clean red ATF coming from the return hose, I reinstalled the line to the reservoir. Topped it off and was done.
It sounds like a similar process for the 5th gen too, right?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
