Old 06-14-2023, 05:24 PM #1
Sgb020 Sgb020 is offline
Sgb020 is on a distinguished road
Power steering fluid?
I was wondering how often you guys change your power steering fluid out? I did mine today at 40k miles. Emptied the reservoir, refilled turned the steering wheels a few times and drove around the block. I did this enough times to use 3 12oz bottles of PSF. I did notice a few particles in the PSF I removed. Hopefully I just didnít waste my money.
Sgb020 is offline   Reply With QuoteReply With Quote
Old 06-14-2023, 06:13 PM #2
djeepin djeepin is offline
djeepin is on a distinguished road
I am so happy you used Idemitsu steering fluid, as I SUSPECT that exactly fluid used in original fluid from factory in all Japanese cars, including Toyota - logic just make sense to me. I really wasn't happy to follow Toyota instructions to use Dextron III, however it is may be compatible, just do not like color in steering, makes it feel like GM
djeepin is offline   Reply With QuoteReply With Quote
Old 06-14-2023, 07:46 PM #3
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
I did it periodically on my '97. It, like my 5th gen TRD ORP, is speced for Dexron II or III ATF. I used Mobil 1 Synthetic ATF in the 3rd gen, and will likely do the same eventually on the 5th gen. It only has 3.5k miles at present.
When I do it, I'll loosen the high-pressure line on the steering rack, and let it drain. Then put the pressure line back on the rack, and fill the reservoir back up. Then start the engine to check for leaks. There will be air in the system initially, so there will potentially be some slight whining, until the air makes it way up to the reservoir. Then go for a short drive turning the wheel full right to left several times, then check and adjust to the correct level in the reservoir.
02SE is offline   Reply With QuoteReply With Quote
Old 06-14-2023, 08:08 PM #4
Makes me wonder or I used the wrong PSF and I should have went with the decron 3.
Old 06-14-2023, 08:20 PM #5
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
After doing nothing for the first 4-5 years, I then started with the Turkey baster method every oil change until 100k where I did the “power off” replacement method. You don’t get much out with a Turkey baster. I’ve been using M1 Dexron III but I think I will switch to the Idemetsu.
1000MPH is offline   Reply With QuoteReply With Quote
Old 06-14-2023, 09:48 PM #6
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Whenever I change engine oil, I use a syringe to empty the PS reservoir and hold the syringe up to a bright light to check fluid clarity and presence of suspended particles. No issues since 2011 and 127K miles.
DougR is offline   Reply With QuoteReply With Quote
Old 06-14-2023, 10:11 PM #7
engeeoh01 engeeoh01 is offline
engeeoh01 is on a distinguished road
I change it every 30k. Use a fluid extractor on the return line and feed new fluid into the reservoir. Redline PSF works well.
engeeoh01 is offline   Reply With QuoteReply With Quote
Old 06-15-2023, 01:31 PM #8
rjtakesphotos rjtakesphotos is offline
rjtakesphotos will become famous soon enough rjtakesphotos will become famous soon enough
Just got it done for the first time at 47k miles. Fully flushed it, it was definitely dirty. I need to do it a bit earlier next time.
rjtakesphotos is offline   Reply With QuoteReply With Quote
Old 06-15-2023, 02:20 PM #9
message's Avatar
message message is offline
message is on a distinguished road
message's Avatar
Maybe I'm the only one doing this, but I thought it was common knowledge?
You can flush the PS fluid by simply jacking the front tires off the ground, removing the PS return line, and turning the wheel clock to clock with the engine off and the key in the on position.
To prevent a mess I plug the return port on the reservoir and extend the return line into a bucket on the floor. As soon as the reservoir is almost empty and before it can suck air, I fill it to the top with new fluid.
Repeat the process a few times until the fluid running out is clear.
No turkey basters, no partial fill, and easy clean exchange of all PS fluid.
2011 Limited - TerrainContact H/T & Blizzak DM-V2 - aFe Pro DRY S - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
2004 SR5 V8 - BFG KO2 - Bilstein Shocks - FJ Springs - Air Lift Bags - Redarc Controller - K&N filter - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
message is offline   Reply With QuoteReply With Quote
Old 06-15-2023, 03:21 PM #10
Rocko9999 Rocko9999 is offline
Rocko9999 is on a distinguished road
75-100K seems about normal. I like Redline products.
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 06-15-2023, 10:39 PM #11
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
I haven't changed the PSF in my 4Runner yet but that's how I did it in my FJ Cruiser. Worked well and was easy.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 06-16-2023, 10:29 AM #12
1000MPH's Avatar
1000MPH's Avatar
Yeah that’s how I do a complete flush but I don’t lift the front wheels all the way off the ground, just enough to still give a bit of resistance.
Old 06-16-2023, 01:01 PM #13
I skipped a bunch of steps in my description, but I also have the tires off the ground, key in the 'ON' position with the engine not running, and then move the wheel/tire assembly from lock-to-lock by hand, to get as much old fluid out of the rack as possible.
Old 06-17-2023, 01:34 AM #14
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
On other vehicles I flush the same way. Near 100% fluid flushed. No mess. Have not done this on the 4runner yet.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 05:10 PM #15
CamposRig CamposRig is offline
CamposRig is on a distinguished road
What do you think about Idemitsu Power Steering fluid that you used in your 5th Gen? I also wonder if this is the OEM/stock fluid used from the factory.
Thanks!
CamposRig is offline   Reply With QuoteReply With Quote
fluid , power , psf , steering , times
Coolant, brake fluid and power steering fluid change and part numbers dcjeeper 5th gen T4Rs 0 03-05-2023 10:24 AM
Whine coming from power steering pump + bubbles in the fluid NOT after fluid change Pyral 3rd gen T4Rs 14 03-19-2022 06:43 PM
Power steering fluid level low. Do I use ATF or power steering fluid? 4flyer 3rd gen T4Rs 63 02-24-2020 05:07 AM
power steering fluid? yeauxkna_at Maintenance/Detailing 12 06-24-2017 12:53 PM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
