Old 12-26-2023, 05:25 PM #16
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
Power Steering Fluid is simply ATF without the red dye.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 07:37 PM #17
Bigdogyj Bigdogyj is offline
Bigdogyj is on a distinguished road
I use atf most of the time as I usually have plenty of that. Otherwise swepco 715 if I specifically need PS fluid.
Bigdogyj is offline   Reply With QuoteReply With Quote
Old 05-29-2024, 02:29 PM #18
japt916 japt916 is offline
japt916 is on a distinguished road
Did you change your Ps fluid with Amsoil OE or the signature 100% synthetic one? how long did you do it? how does the PS been working?
japt916 is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 10:51 PM #19
I only use Idemitsu Bukaki power steering fluid. Never have any circle jerks in 4wd on dry pavement.
Old 06-07-2024, 11:33 PM #20
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Looks like NAPA has the Idemitsu PSF for a more reasonable price than Amazon if anyone is interested.
Just a moment...
1000MPH is offline   Reply With QuoteReply With Quote
Old 06-19-2024, 04:23 PM #21
pdx650's Avatar
pdx650 pdx650 is offline
pdx650 is on a distinguished road
pdx650's Avatar
Originally Posted by message View Post
Maybe I'm the only one doing this, but I thought it was common knowledge?
You can flush the PS fluid by simply jacking the front tires off the ground, removing the PS return line, and turning the wheel clock to clock with the engine off and the key in the on position.
To prevent a mess I plug the return port on the reservoir and extend the return line into a bucket on the floor. As soon as the reservoir is almost empty and before it can suck air, I fill it to the top with new fluid.
Repeat the process a few times until the fluid running out is clear.
No turkey basters, no partial fill, and easy clean exchange of all PS fluid.
I did the same method in 2011 on my 3rd gen. Check my photos. Works like a charm.
MH-139A Grey Wolf Mechanic.
pdx650 is offline   Reply With QuoteReply With Quote
Old 06-25-2024, 09:21 AM #22
Mo's TE Mo's TE is offline
Mo's TE is on a distinguished road
Anyone having heavy steering wheel? I changed the oil using the baster method over several days but it did not help. I'm running 285s since new. I cannot tell at which point the steering became heavy.
Mo's TE is offline   Reply With QuoteReply With Quote
Old 06-25-2024, 06:52 PM #23
1000MPH's Avatar
1000MPH's Avatar
Only after driving other cars with light steering.
fluid , power , psf , steering , times
Coolant, brake fluid and power steering fluid change and part numbers dcjeeper 5th gen T4Rs 0 03-05-2023 10:24 AM
Whine coming from power steering pump + bubbles in the fluid NOT after fluid change Pyral 3rd gen T4Rs 14 03-19-2022 06:43 PM
Power steering fluid level low. Do I use ATF or power steering fluid? 4flyer 3rd gen T4Rs 63 02-24-2020 05:07 AM
power steering fluid? yeauxkna_at Maintenance/Detailing 12 06-24-2017 12:53 PM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
