Originally Posted by NorthPark
Can you duplicate the sound with the vehicle off?
Try to drive it over some speed bumps at different speeds and angles and see if you can hear it. Go slow but try to find different ways of actuating the suspension, do front and then rear as you go over them.
Get up on your sliders/steps if you have them, grab your roof rack and just rock it as hard as you can side to side
A notorious loud clunk is the rear upper control arm frame side after a lift. It's difficult to get up in there and torque those bolts properly. The few times I've ran into missing upper control arm bolts, the noise was heard while parking forward and reverse. The noise was not present with normal driving
Bushings can make a pop sound, but usually if it's a loud bat type of sound then a suspension component is loose
Can't duplicate with off or neutral....I did try rocking it really hard...no noise.
I haven't heard it over speed bumps or driving speed when hitting bumps.
Just picked up and it has stopped. One of the serv "advisors" tried to rexplain the meshing bs again...but after I showed him the video and he heard it...he agreed that it was not normal.
It has stopped for now..but I am going to test it further to see if I can get it to come back.
