Old 06-20-2023, 03:52 PM #1
tmhernandez77 tmhernandez77 is offline
tmhernandez77 is on a distinguished road
Question Wiring under steering wheel
I bought a used 5th gen sr5 (2013) this past week, and it has raptor lights and a pair of fog lights that I cannot figure out how to turn on. I decided to pull the dash off under the steering wheel ro inspect the wiring and it's a total mess. There's a few loose wires not attached to anything, some fuse connectors and wires with in-line fuses in there, etc. I'd like to bring it back to stock and get a switch panel to wire everything cleanly. Can anyone direct me to a wiring diagram and or some labeled pictures I could use to get everything sorted out?
Thanks!
tmhernandez77 is offline   Reply With QuoteReply With Quote
Old 06-20-2023, 04:06 PM #2
Ripper238's Avatar
Ripper238's Avatar
Its going to be a difficult task if you cant just tell by looking at the wiring, and try not to disconnect the lower air bag.
Maybe bring it to a local car audio shop?
Old 06-20-2023, 04:20 PM #3
Whippersnapper02's Avatar
As they say, only the bomb maker knows what wire does what. They don't come on with the headlights?
Old 06-20-2023, 08:40 PM #4
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
All wiring diagrams are on TIS, but there are hundreds for a particular vehicle. You can get a subscription to TIS or try to talk your dealer into printing some out for you.
One approach, which may help in your case, is to start at the non-Toyota lights and follow the wires back to where ever they go. Then remove just those wires. Theoretically, that should leave only OEM wires.
fkheath is offline   Reply With QuoteReply With Quote
Old 06-21-2023, 10:38 AM #5
emmantik emmantik is offline
emmantik is a jewel in the rough emmantik is a jewel in the rough emmantik is a jewel in the rough emmantik is a jewel in the rough
For the raptor lights, can you not just follow the wires from the lights to see where they lead to? They should just turn on when the vehicle is on, no? (assuming they are not wired to an aftermarket switch)
For the fog lights, I believe you can only turn them on when the headlights are on. Unless you have some sort of aftermarket control/harness. I am also coming from a 2015 so might be different on your early model 5th gen.
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 06-21-2023, 01:59 PM #6
The raptor lights do not turn on when the car is on, and I cannot get the fog lights to come on with the headlights, high beams, anything. I'm gonna try to remove the wiring coming from the raptor and fog lights, should help me make sense of everything.
Old 06-22-2023, 02:01 PM #7
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Check the fuses under the dash for a burnt out one or maybe a damaged ADD-A Fuse if theres one there. You should be able to see where power line comes through firewall and goes into the mini fuse box just sort of above the E brake pedal.
2016 Limited--Kings, Shrockworks, Sherpa rack, Rago stuff K02s, STT Pros, Blizzak Snows,
Baja fogs, 40" S8, XL80s
LED rears, Full RCI skids, diff skid, gas skid
Russian shovel with sharpened blade and grip tape!
SPOD, ---2021 Limited- STOCK
Grug556 is offline   Reply With QuoteReply With Quote
Old 06-22-2023, 05:14 PM #8
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
What's the over/under that the previous owner ripped out a switch controller before selling
Also are these stock fog lights?
NorthPark is offline   Reply With QuoteReply With Quote
Old 06-23-2023, 11:58 AM #9
I defused the bomb! Pulled a bad add-a-fuse and whatever wires went through the firewall. Just had to splice together a wire that the previous owner cut and I got it back to stock configuration. I did find a GPS tracker stashed under there as well, but I called the dealership that sold it to the guy and confirmed it was theirs, so I just yanked it and tossed it in the trash. New problem, im adding an auxbeam to prevent future shenanigans, and I just need to know which fuse to use in the main fuse box in the engine compartment. I need to put an add-a-fuse in somewhere to a circuit that is only on when the car is either on or in acc mode. Anyone able to tell me which fuses I can safely use for this? Thanks.
lights , steering , wheel , wires , wiring
Loose steering and wobbly steering wheel even after steering rack bushing replacement psyduck 3rd gen T4Rs 18 07-17-2022 07:17 PM
Replacing steering wheel with another Toyota/Lexus model steering wheel LexusFTW 3rd gen T4Rs 20 03-04-2021 12:24 AM
Steering Wheel Wiring Diagram drewsro 5th gen T4Rs 3 12-01-2019 09:14 PM
XUJI leather steering wheel cover install. Goodbye plastic steering wheel. OEM? Kelbad 5th gen T4Rs 24 05-19-2019 03:51 AM
Steering Controls on the Right Side of the Steering Wheel subzero Engines / Suspension / Wheels / Tires / Audio / Accessories 10 08-03-2006 05:16 AM
