Old 07-17-2023, 02:08 PM #16
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
I was luckily enough where the nut seized onto the stud but was able to back out the stud.
blksubykid is offline   Reply With QuoteReply With Quote
Old 07-29-2023, 10:53 PM #17
cheeser cheeser is offline
cheeser is on a distinguished road
I was unable to extract the broken stud, but was able to cut / grind down the broken stud with a Dremel, then drill through with an 1/8” and 1/4” drill with 12” extension, and then use a through bolt and nut.
2023 SR5 Eibach Stage 2R, Hefty FabWorks Slider, Falken AT4W
Sold- 2016 TE w/KDSS, Bilstein 6112 (6 passenger, 5 driver) & 5160 w/T13 springs, Firestone Destination AT, Hefty FabWorks Sliders, IS 690TOY Speakers, Husky Liners WeatherBeaters, Covercraft SeatSavers
cheeser is offline   Reply With QuoteReply With Quote
Old 02-04-2024, 03:39 PM #18
sprouty115 sprouty115 is offline
sprouty115 is on a distinguished road
Do you have a link for the extension you bought? I have the same issue on my 2018 4 Runner (both studs!). I have the studs ground flush, but I am struggling to find something to get a drill bit to reach the flange area.
Edit: So I got it sorted and just in case anyone stumbles across this thread here is what what I did...
- First, the only thing I could seem to find outside of the McMaster-Carr rod-with-a-collet (expensive) was a "drill chuck with a 1/4" hex shank". I couldn't find it locally so I ordered from Amazon and it was delivered by 10:00AM the day after I ordered it.
By 10:15AM I realized why it cost $9...the entire thing disintegrated halfway through the first hole. Fortunately, I remembered a local hardware store that somehow seems to have everything so I gave them a call and sure enough, they actually had one. It was made of steel and it did the job, though I'm not sure it will last a lifetime...
After that it was a matter of getting the drill centered and taking my time not to break anything. I ended up using the magnetic bit holder extension that I happened to have available, and that was pretty wobbly, though it did work. But if I had it to do all over again, I would order an extension that had two set screws to lock the drill chuck hex in-place (search for "Spade Bit Extention" to see what I mean).
Also, I drilled it to 1/4", which is slightly larger than the 6mm stud. And I did it in one shot, rather than start small and progressively drill it larger. I reason that it's a lot harder to break a 1/4" drill than a 1/8" drill, and I didn't want to have to deal with getting a small, broken drill out.
BTW, I didn't get an estimate of the cost to bring it to a dealer, but if I were to guess, I'm thinking it would be the better part of $1K if the manifold had to be replaced.
2016 4Runner spark plug replacement  - broke emission tube stud-drill-chuck-jpg  2016 4Runner spark plug replacement  - broke emission tube stud-sas-manifold1-jpg  2016 4Runner spark plug replacement  - broke emission tube stud-sas-manifold-jpg
sprouty115 is offline   Reply With QuoteReply With Quote
Old 06-10-2024, 12:08 AM #19
toddsun toddsun is offline
toddsun is on a distinguished road
I did the same thing today to the left stud.
Used a 1" clamp as a temp fix (maybe it will work just fine permanently).
Will check it pediodically to see it the clamp got loose.
2016 4Runner spark plug replacement  - broke emission tube stud-image1-jpg  2016 4Runner spark plug replacement  - broke emission tube stud-image00-jpg  2016 4Runner spark plug replacement  - broke emission tube stud-image11-jpg
toddsun is offline   Reply With QuoteReply With Quote
Old 06-10-2024, 07:03 PM #20
I didn’t see this for some reason, but I used a hex extension. The most difficult part was getting a dremel tool in there to cut/flatten the remaining stud portion of the stud. Once flattened and center punched, the stud was easy to drill out.
I just bought a new 4Runner and went ahead and removed these nuts on both sides, used a dab of antisieze on the stud, and reinstalled/ torqued the nuts…but of future proofing.
Old 06-10-2024, 10:35 PM #21
the clamp is gonna really throw off the next owner of that 4runner
smart man
Old 06-11-2024, 12:12 PM #22
teotwaki's Avatar
teotwaki teotwaki is offline
teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice
teotwaki's Avatar
Originally Posted by CutthroatSlam View Post
Why were you removing the nuts from that end of the air tube to replace the spark plugs? Only need to remove the bolts at the air valve holding that tube, then remove the valve.
To illustrate your point I performed a quick edit of one of the photos. When I change my 2018's plugs I'll try to get a better shot.
Does this look about right?
2016 4Runner spark plug replacement  - broke emission tube stud-air-tube-jpg
Jim _ My Adventure Blog:http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
teotwaki is offline   Reply With QuoteReply With Quote
Old 06-13-2024, 08:51 PM #23
hoobhoob's Avatar
hoobhoob hoobhoob is offline
hoobhoob is on a distinguished road
hoobhoob's Avatar
Reminds me of an oil pressure sender block crack I had to fix (gen2 RAV4 2.4.) The fix lasted the vehicle's remaining 95K km.
hoobhoob is offline   Reply With QuoteReply With Quote
driver , exhaust , removing , side , tube
Spark Plug Tube Seal Replacement / Install yotaah 3rd gen T4Rs 7 01-04-2024 11:52 PM
Spark Plug Tube Gaskets - How do they fit? thrice1825 3rd gen T4Rs 20 10-27-2015 08:56 PM
Oil leak around top of spark plug tube snowninja 3rd gen T4Rs 5 11-23-2013 01:45 AM
2005 4runner v8 4wd spark plug replacement toyota gal General Discussions 2 10-25-2012 03:49 PM
Spark Plug Tube Seal jetdrivr 3rd gen T4Rs 3 09-27-2006 04:58 AM
