Old 07-17-2023, 02:08 PM #16
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
I was luckily enough where the nut seized onto the stud but was able to back out the stud.
blksubykid is offline   Reply With QuoteReply With Quote
Old 07-29-2023, 10:53 PM #17
cheeser cheeser is offline
cheeser is on a distinguished road
I was unable to extract the broken stud, but was able to cut / grind down the broken stud with a Dremel, then drill through with an 1/8” and 1/4” drill with 12” extension, and then use a through bolt and nut.
2023 SR5 Hefty FabWorks Slider, Falken AT4W
Sold- 2016 TE w/KDSS, Bilstein 6112 (6 passenger, 5 driver) & 5160 w/T13 springs, Firestone Destination AT, Hefty FabWorks Sliders, IS 690TOY Speakers, Husky Liners WeatherBeaters, Covercraft SeatSavers
cheeser is offline   Reply With QuoteReply With Quote
Old 02-04-2024, 03:39 PM #18
sprouty115 sprouty115 is offline
sprouty115 is on a distinguished road
Do you have a link for the extension you bought? I have the same issue on my 2018 4 Runner (both studs!). I have the studs ground flush, but I am struggling to find something to get a drill bit to reach the flange area.
Edit: So I got it sorted and just in case anyone stumbles across this thread here is what what I did...
- First, the only thing I could seem to find outside of the McMaster-Carr rod-with-a-collet (expensive) was a "drill chuck with a 1/4" hex shank". I couldn't find it locally so I ordered from Amazon and it was delivered by 10:00AM the day after I ordered it.
By 10:15AM I realized why it cost $9...the entire thing disintegrated halfway through the first hole. Fortunately, I remembered a local hardware store that somehow seems to have everything so I gave them a call and sure enough, they actually had one. It was made of steel and it did the job, though I'm not sure it will last a lifetime...
After that it was a matter of getting the drill centered and taking my time not to break anything. I ended up using the magnetic bit holder extension that I happened to have available, and that was pretty wobbly, though it did work. But if I had it to do all over again, I would order an extension that had two set screws to lock the drill chuck hex in-place (search for "Spade Bit Extention" to see what I mean).
Also, I drilled it to 1/4", which is slightly larger than the 6mm stud. And I did it in one shot, rather than start small and progressively drill it larger. I reason that it's a lot harder to break a 1/4" drill than a 1/8" drill, and I didn't want to have to deal with getting a small, broken drill out.
BTW, I didn't get an estimate of the cost to bring it to a dealer, but if I were to guess, I'm thinking it would be the better part of $1K if the manifold had to be replaced.
2016 4Runner spark plug replacement  - broke emission tube stud-drill-chuck-jpg  2016 4Runner spark plug replacement  - broke emission tube stud-sas-manifold1-jpg  2016 4Runner spark plug replacement  - broke emission tube stud-sas-manifold-jpg
sprouty115 is offline   Reply With QuoteReply With Quote
driver , exhaust , removing , side , tube
Spark Plug Tube Seal Replacement / Install yotaah 3rd gen T4Rs 7 01-04-2024 11:52 PM
Spark Plug Tube Gaskets - How do they fit? thrice1825 3rd gen T4Rs 20 10-27-2015 08:56 PM
Oil leak around top of spark plug tube snowninja 3rd gen T4Rs 5 11-23-2013 01:45 AM
2005 4runner v8 4wd spark plug replacement toyota gal General Discussions 2 10-25-2012 03:49 PM
Spark Plug Tube Seal jetdrivr 3rd gen T4Rs 3 09-27-2006 04:58 AM
