Old 07-06-2023, 03:35 PM #1
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
Any way for 12v and USB outlets to have constant power?
With the vehicle turned off, none of the USB or 12V ports in the 4Runner work.
Any way to change this? I'll be installing a dual battery set up this year, and want to be able to run a fan out of the far rear 12v and phone chargers with the vehicle off.
Thanks in advance!
2020 Army Green TRD Pro 4Runner | IG: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit the LinkTree on my Instagram for discounts on Rock Sliders,
Molle Panels, Ark Splash guards, Canvasback liners, Insta360 Cameras,
Camera Mounts, LED Bulbs, RRW Wheels, Power Washers, and more!
TRDHULK is offline   Reply With QuoteReply With Quote
Old 07-06-2023, 04:34 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Thanks in advance!
I'm sure you've considered this but run a line directly to the house battery and add a new 12v port. Off Grid Engineering makes a kit for this or you can DIY fairly easily. I thought this was easier than rewiring existing ports
'13 TE w/ KDSS, 4:56 Gears, Dobinson's IMS C59-352/C59-701V, Sonoran Steel KDSS Trac Bar, Overland Custom Design Control Arms. Fuel Revolver 17x9 +1 mm 5" Backspace, Falken Wildpeak A/t3w 285/75r17, Hefty Fabworks Aluminum Front Bumper and Full Skids, C4 Fab Dual Swingout Rear Bumper, OPOR Sliders, Northstar, Off-Grid Engineering, SPod, Blue Sea, Rigid, Baja Designs, KC HiLites, Stedi, Aplharex, National Luna, Drifta, Goose Gear, RAD Rubber Designs, Viair, Bandi Mount, URD, Gobi, ARB, Warn, Factor 55, Fourtreks, Axia Alloys, Desert Does It, Agency 6
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 07-06-2023, 05:50 PM #3
TRDHULK's Avatar
TRDHULK's Avatar
Good info. Was hoping there was an easier way, but I can always do this. Thanks
Old 07-07-2023, 11:19 AM #4
Rocko9999 Rocko9999 is offline
Rocko9999 is on a distinguished road
Any way to do a timed port? I recall some older vehicles I had turned off the 12v ports at 20 or 30m which was very useful.
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 07-07-2023, 02:09 PM #5
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
That's the more common solution. This way you also isolate any of your added electrical systems from the factory wiring. Way easier to maintain and troubleshoot that way too.
Personally I added a second fuse block and ran all my auxiliary circuits off of that, including a new power panel in the rear controlled with a switch back there too.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 07-07-2023, 03:23 PM #6
Yamahamer Yamahamer is offline
Yamahamer is on a distinguished road
^This! That's what I've done to all my vehicles. I'm part of a SAR group so on a search I run at least 2 GPS units plus other electronic equipment and I don't want all that stuff shutting down just because I've turned off the ignition.
Mount something like this out of the way somewhere.
Amazon.com
Then mount something like this where its easily accessible. Cut off the cigarette lighter plug on the end and connect the wires directly to the fuse block. You'll have plenty of always-on power points and USB connections...just remember to switch off the power to this to keep from getting a dead battery.
Amazon.com
Yamahamer is offline   Reply With QuoteReply With Quote
Old 07-07-2023, 03:28 PM #7
Auntie Soshul's Avatar
Auntie Soshul Auntie Soshul is offline
Auntie Soshul is on a distinguished road
There is a how-to in the stickies for running constant power to the 12 volt outlets.
2013 SR5 Mag Gray, Pre-leveled, Non-nosedive edition
Plastic license plate frame
Auntie Soshul is offline   Reply With QuoteReply With Quote
Old 07-07-2023, 05:00 PM #8
TRDHULK's Avatar
TRDHULK's Avatar
You have pics and details on this??
Old 07-07-2023, 05:01 PM #9
TRDHULK's Avatar
TRDHULK's Avatar
Thanks! Didnt know
Old 07-07-2023, 05:26 PM #10
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
easiest way for me to do this was run the ARB fridge wiring kit from battery to a marine socket panel (kill switch, 12 volt meter, USB, and cigarette plug).
Using the ARB fridge wiring kit made it really easy, no splicing, no guess work on fuse placement, all wiring and fuses included, etc.
Then attach whatever accessory socket panel you want to it. You can go super fancy or super simple. Again no splicing or anything.
Here is the pic of mine, but yeah all i needed was the ARB wiring kit and a panel.
I did not wanna hack into existing vehicle wiring.
Any way for 12v and USB outlets to have constant power?-thumbnail-104-jpeg
Old 07-07-2023, 05:40 PM #11
I might have some...I did it when the truck was new three and a half years ago. Lots of members have done the same thing though and they probably already have it documented as well.
I can take some over the weekend and post them up.
Gone
Old 07-13-2023, 01:05 PM #12
TRDHULK's Avatar
TRDHULK's Avatar
This is awesome! This is what I want. Thanks for sharing!
Old 07-17-2023, 11:39 AM #13
TurboX TurboX is offline
TurboX is on a distinguished road
This is what I did, Cig lighters and USB power all the time
Any way for 12v and USB outlets to have constant power?-cdlp-1-jpeg
TurboX is offline   Reply With QuoteReply With Quote
Old 07-18-2023, 10:31 AM #14
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
Hey Turbo, can you please explain what you did here in that pic. Looks like you pulled a diode from the fuse box, what is it for and did you replace it after?....Thanks Jim
2019 ORP KDSS MagGrey RSG Sliders 255/75/17 KM2 MT/ICS Fab above console mount
IslandJim is offline   Reply With QuoteReply With Quote
Old 07-18-2023, 12:33 PM #15
I found it online somewhere searching how to have constant power, I’ve had it for about 4 months with zero issues.
Basically built jumper from hot source to dc power circuit.
12v , battery , fan , usb , vehicle
Constant 12V power outlets Kmvreter Engines / Suspension / Wheels / Tires / Audio / Accessories 155 07-31-2022 02:28 PM
ISSUE: Constant Power to Outlets Kilo_ 4th Gen T4Rs 5 01-08-2020 12:19 AM
Mod: Add Constant and Accessory Power Outlets NH_T4r 4th Gen T4Rs 6 05-08-2018 04:11 PM
power outlets not producing full charging power outgolfin0 4th Gen T4Rs 9 10-14-2013 12:39 PM
X-post: "Constant power" to 12v outlets done! Martinjmpr 4th Gen T4Rs 0 11-05-2012 02:53 PM
