Old 07-12-2023, 11:03 AM #1
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
Installed a ProCharger
So I installed a ProCharger over the past two weekends and started it up last night for the first time
It's not nearly as loud at idle as everyone makes it seem. The kit install is relatively easy except for it being very cramped around the head unit.
I still have a few issues to sort out, mainly the inlet is touching the radiator no matter what I do. There is also a bit of a crimp in the outlet elbow that I need to sort out.
Just to make it clear - the ProCharger WILL NOT work with a CSF radiator. This sent me scrambling in the middle of the install to try and source an oem radiator. The pics of the ProCharger setup always show this area covered by the radiator cover, it's not very obvious how close the inlet is to the radiator. I spoke to ProCharger but couldn't get any answers as to how much clearance there should be with the radiator or how well this has fit in other vehicles. This CSF issue would have been a deal breaker for me had I known ahead of time. The whole point of this setup was to keep the temps as low as possible as I live in AZ - another reason why I skipped the mag.
This pic is before I shaved about 8mm off of the face of the inlet (it still touches)
As this is an off-road desert vehicle, I'm not very comfortable with things rubbing up against the radiator
Anyway it's hot as hell outside and it was just started up late last night, it'll be a few days before I can answer on the power delivery
NorthPark is offline   Reply With QuoteReply With Quote
Old 07-12-2023, 11:05 AM #2
The head unit will need to be removed to access the front drivers area of the engine bay, but this takes about 20 minutes and is relatively easy as it's a self contained unit. I installed a power steering cooler as well and now have to remove the head unit to fix something with the new drivers side hard line.
Old 07-12-2023, 05:38 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Cool
Should be interesting.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 07-12-2023, 06:08 PM #4
HuskyMike HuskyMike is offline
HuskyMike will become famous soon enough
Cool. Maybe heat gun on the intake tube and mold it out of the way?
HuskyMike is offline   Reply With QuoteReply With Quote
Old 07-12-2023, 08:28 PM #5
nice. thats annoying it rubs the radiator. stock radiator is fine, did you also add an external trans cooler? thatd be on my list before a radiator simply for the cruises up the 87.
Old 07-12-2023, 10:22 PM #6
I have a b&m w/ fan and also a radiator style going in with a thermostat bypass. I'll most likely install them on the passenger side from the way it's looking. I bought some aluminum flat bar that I'm hoping to use for brackets
Old 07-16-2023, 12:57 PM #7
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Any updates @NorthPark ?
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 11:16 AM #8
TurboX TurboX is offline
TurboX is on a distinguished road
Is this a kit or something you fabbed up ? A centrifugal blower wouldn't be my first choice unless you put a very small pulley to bring boost on low. Also how are you handling tune ? I see race truck and just curious if this is steetable or some one off you did and have a aftermarket PCM.
Thanks
TurboX is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 11:33 AM #9
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Thanks
Procharger sells a bolt on kit for these. Tuning is probably done with a reflash like vftuner.
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 11:43 AM #10
The inlet and the oem radiator are still rubbing, but I started it up over the weekend. The idle sound is interesting but it's not all that bad.
Right now it's throwing rich codes (p0172/p0175).
Since I did have issues with the CSF radiator, I decided to follow the book 100% and in doing so I tossed in the fresh k&n filter.
I'm hoping just the maf is dirty or gunked up by the filter. I double checked the vacuum lines but I'll run a smoke machine to verify.
short term fuel trim on both banks is -20%. This was the first start up and I had vcf scanner going, it didn't seem to let me verify the fuel pressure (no fp sensors?) so I'll get my electric fuel pressure gauge setup asap.
Progress is slow as it was 110f in my garage over the weekend, so I can only spent an hour or two at a time in there.
Old 07-18-2023, 09:45 AM #11
ProCharger_Rep01 ProCharger_Rep01 is offline
ProCharger_Rep01 is on a distinguished road
If you have any issues or need assistance feel free to give us at ProCharger a call at 913-338-2886 or fill out this contact us form (Contact Us - ProCharger Superchargers) and we will reach out! Thanks!
ProCharger_Rep01 is offline   Reply With QuoteReply With Quote
Old 07-18-2023, 01:16 PM #12
Okay so new update.
I cleaned my MAF last night due to the odd idling and now it won't start at all. It cranks but that's about it. No fuses blown under the dash or engine bay that I can find. No difference with the maf disconnected.
ODBii is no longer readable by any of my scanners so I can't pull any codes. This is new along with the no starting.
Nothing changed other than just cleaning the maf with crc cleaner.
I did find that my (ProCharger provided) positive battery terminal cracked in half and was loose on the battery. It was probably loose when I had started it up, hopefully this didn't fry something. I want to run higher quality cables anyway so these were only there just to get this running.
my odyssey 34r was sitting on a trickle charger this entire time and is fully charged.
Old 07-18-2023, 07:49 PM #13
1: Odd hum coming from the engine bay, looks like rear of the engine. I can't figure out where the sound is coming from, but removing fuse 14 ECU-IG NO.2 silences it. I'm not sure when this started.
Here's a vid:
Imgur: The magic of the Internet
2: Still cannot communicate with the ECU via ODB. It suddenly stopped working after a scan. My scanners can pull codes from other devices, just not the main ECU.
3: Got my fuel pressure gauge hooked up. It hits 35 PSI when cranking. Doesn't seem to drain all that fast.
This happened over night, it was starting yesterday and throwing P0172/P0175 codes. I cleaned the MAF and then this all happened. I'm going to find a MM and check the voltages on the ODB port, otherwise thinking about maybe pulling a spark plug just to take a look.
Old 07-18-2023, 09:07 PM #14
Odb port voltages
Pins
4-16 12.07
4-7 11.30
Same results when using pin 5 as ground.
I’m starting to suspect a battery issue. It tests ok but rapidly loses voltage. The battery charger says it needs a full charge after it had a full charge yesterday
Old 12-12-2023, 09:37 PM #15
wcslv wcslv is offline
wcslv is on a distinguished road
NorthPark, did you figure out what happened? If you did how’s it running now?
2019 T4R TRD PRO
wcslv is offline   Reply With QuoteReply With Quote
inlet , install , procharger , radiator , sort
Procharger install thread (this will take awhile) scratchhax 5th gen T4Rs 98 09-26-2022 01:16 AM
first tow with the procharger scratchhax 5th gen T4Rs 5 08-01-2022 09:32 PM
4Runner/Tacoma Procharger Whippersnapper02 5th gen T4Rs 61 03-26-2021 01:19 PM
Anyone seen this yet? Procharger superchager 03_4x4Runner 5th gen T4Rs 29 03-14-2021 01:46 PM
ProCharger for the 4Runner Eddie Haskell 5th gen T4Rs 4 11-27-2019 11:56 PM
