Old 07-13-2023, 01:04 PM #1
Synstars Synstars is offline
Synstars is on a distinguished road
Service question on coolant and brake fluid
Dealer wants to “flush” coolant system. Is this advised or do we just typically drain/refill on the 5th gen? They want almost $200.
Also, with replacing brake fluid on a 2018 ORP since it has an electric pump for the brakes can I just put a weight on the brake pedal with acc on and bleed it that way?
Thanks all chilling at the dealer now for a cheap oil change.
Synstars is offline   Reply With QuoteReply With Quote
Old 07-13-2023, 05:43 PM #2
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Coolant doesn’t need a flush for a 2018. Just drain and refill. If you continue at this cadence you shouldn’t ever need a flush for your coolant.
Yes, you can cycle through all of your brake fluid with the standard method. You don’t have to use the electric assist, but you can. Just don’t let the reservoir/master cylinder go empty and draw air in!
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 07-13-2023, 06:52 PM #3
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
How often do you change your coolant and brake fluid? I know the DYI says every 15k after 60k for coolant and brake fluid every 3 years but that seems very early. I guess it depends on your driving.
2016 TRD Pro Quicksand
Lexington is offline   Reply With QuoteReply With Quote
Old 07-13-2023, 07:01 PM #4
Lexington's Avatar
Lexington's Avatar
Here is the link for the DYI. I think some of the recommendations are much sooner than the manual but a good guide none the less.
DIY maintenance quick reference
Old 07-14-2023, 09:24 PM #5
My ‘21 maintenance manual calls for coolant replacement at 100k miles and every 50k miles after. I am comfortable with this interval on an all aluminum block/head engine. I will probably replace at 50k and every 50k after just because I can. On an engine with an iron block I would replace more frequently and if the original owner didn’t change prior to 100k I would flush first. Lots of rust particles in my iron block and head 6BT.
Every 3 years to replace brake fluid is a good interval. It’s hygroscopic so it absorbs water over time. Plus brakes and tires are the most critical maintenance items for your safety.
brake , coolant , dealer , fluid , put
Coolant, brake fluid and power steering fluid change and part numbers dcjeeper 5th gen T4Rs 0 03-05-2023 10:24 AM
New Radiator with Coolant Flush? Power Steering Fluid Flush, and Brake Fluid Flush? jdotlim 4th Gen T4Rs 4 09-17-2017 07:52 PM
Brake fluid leak after dealer service... rblt Off Topic 2 10-12-2016 03:27 PM
Coolant fluid question LUVDA4RUNNER 4th Gen T4Rs 3 12-27-2013 01:12 AM
Maintenance: When do we change brake fluid, power steering, coolant Mabuse 4th Gen T4Rs 2 08-25-2009 05:02 PM
