07-19-2023, 12:03 PM
#1
Member
Member
How many hours of labor to install rock sliders?
I have a quote from a 4x4 shop in town to install rock sliders on my 4runner 2020 (kdss). They quote me 5 hours of labor which seems on the high side to me. These rock sliders don't require drilling of any new holes (that's what the manufacturer claims). I called the shop several times and they stand by these 5 hours, saying that from their experience it's what it takes to install rock sliders on cars, tidy up all cables, etc, etc.
At an hourly rate of $125, this adds up quickly. What do you folks think? Is this reasonable or not? The manufacturer said that this should take 1-2 hours only....
07-19-2023, 12:09 PM
#2
Member
Member
If you’re a bit handy with tools, you should be able to get them done with the help of a buddy and a 6 pack and maybe a pizza. I certainly wouldn’t pay for that much in labor. They are right, it’s a one to two hour job max.
Either way, never go back to that shop cuz they’re ripping you off.
#3
Member
Member
Oh, and plenty of YT videos out there on install procedures.
07-19-2023, 12:19 PM
#4
Member
Member
Quote:
Thanks but I'd rather have a shop do this.
07-19-2023, 12:59 PM
#5
Member
Member
Quote:
Then start calling other shops. Or…Get ready to write the $600 check and quit your complaining. Sheesh!
07-19-2023, 01:06 PM
#6
Elite Member
Real Name: Chris
Elite Member
Real Name: Chris
5 hrs is insane!
__________________
2017 Nautical Blue SR5 Premium - Black Emblems, AFE 76mm TB, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, VR ECU Tune, RCI Skid Plate, Morimoto MLED 2.0 Headlight Retrofit, Morimoto LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Tinted Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, CaliRaised Rock Sliders, BajaRack Full Length Roof Rack, Kenwood DMX1057XR, Infinity Kappa Door Speakers and 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, Blackvue DR900S Dash Cams
07-19-2023, 07:42 PM
#7
Junior Member
Junior Member
Not sure what’s harder. Installing sliders or a light bulb.
07-19-2023, 08:32 PM
#8
Elite Member
Elite Member
It doesn't take much more than 5 hours to make them. In most cases you're just aligning the holes to nuts that are already in the frame rail and putting in small bolts and then tightening the bolts. It's about 10 bolts per side total. Install by a professional shop should be 1-2 hours in most cases. They've probably never installed them on a 5th gen. Some are much more complicated than this. My 3rd gen 4Runner sliders for example were much more involved to install.
Also - Pro tip. Purple Loctite is your best friend! It's the low adhesion version. Blue is also fine for this. But I love purple because it seals the threads and keeps them from rusting and also helps keep them from backing out. I find it works better than antisieze for applications like this. You'll probably have to order on Amazon. But it's my go-to for applications like this. Worth the $7 for a bottle of it.
07-19-2023, 12:20 PM
#9
Member
Real Name: Eric
Member
Real Name: Eric
Me and my 9 year old son put my metal tech sliders on in less than an hour. I jut balanced them on a floor jack and had him tweak the jack position while I got all the bolts installed. No KDSS or anything in the way but I can't imagine 5 hours being reasonable in any scenario.
07-19-2023, 03:40 PM
#10
Member
Member
Quote:
I need a helper dang it! They better shine up the complete underside of your truck too after they finish in thirty minutes. I can fabricate, bend and weld rock sliders faster than that. For $50-$100 of tube/pipe. I will have to sweat my a$$ off though. Just sit there and watch them 😆 that may cut a few hours off.
07-19-2023, 04:29 PM
#11
Senior Member
Senior Member
Most of them will be really easy.
Some of them use welded nuts inserts that you fish though the frame, those suck and will take longer (AKA shrockworks).
Give yourself 2 to 4 hours. Shop time can vary.
Honestly, this can be done in your driveway by yourself with hand tools, a jack (optional to hold sliders in place if doing solo).
__________________
2016 trail 4runner, twin locked on 34's.
Can read more of my build here (2 parts):
https://www.lasfit.com/blogs/news/ho...ad-build-part1
07-19-2023, 04:38 PM
#12
Member
Member
This reminds me of the dealer trying to charge you an hour of labor to change the cabin air filter.
__________________
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
07-20-2023, 02:07 PM
#13
Member
Member
Took me a little over an hour by myself with a floor jack
__________________
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
07-20-2023, 02:29 PM
#14
Member
Member
Quote:
i totally agree that a truck without KDSS should be 60-90 min. the OP has KDSS and there are hydraulic lines that run along the frame on the driver's side that make slider installs a PAIN. passenger side took me like 30-40 min. the driver said took me over 2 hours, especially because the caliraised bracket requires you to lower the gas tank skid so I was trying to line up the slider while keeping hydraulic lines away from the frame. not fun.
__________________
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
07-24-2023, 09:16 AM
#15
Member
Member
How can it take more than an hour or two?
I just took delivery of a '23 ORP w/KDSS that came from the distributor with nfab's Predator running boards/steps. (And the old black Pro wheels, and a bunch of tacked on stuff thanks to the distributor for Virginia. At least it didn't come with the mandatory blackout letters, cargo cover, charging cords and various other junk. But I digress.)
I wanted the same running boards that came on my '16 Trail Prem - the ones with the pattern that matches the black cover on the rear bumper.
For taking the Predators off and putting on 6 new brackets, installing the full-length metal plates and then the plastic running board covers with the pattern that you see...
They charged me for 2 hours labor for a more complicated install.
They deducted the price of the Predators - $665 - from the cost of the deal and they had also deducted the price of the bug shield. Yay.
Oh, and they removed the bug shield for free.
LAUGH OF THE DAY.
When I went back to pick it up THE PREDATOR BOARDS AND THE BUG SHIELD WERE IN THE BACK. I said, "What's this?"
They said, "We don't want them, go sell them."
__________________
2023 TRD ORP w/KDSS. Red again.
This 2016 TEP w/KDSS is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
