Old 07-19-2023, 07:14 PM #1
RAVL 2016 RAVL 2016 is offline
RAVL 2016 is on a distinguished road
2016 T4R Four wheel brake job cost
My 2016 4Runner will soon need pads front and rear as they are down to about 2mm. Do people have any recent prices for the cost of a four wheel brake job with pads, light rotor resurfacing, and brake flush? I feel like the price of everything is so much more than I last remember, so I would like to get a better sense. Thank you.
RAVL 2016 is offline   Reply With QuoteReply With Quote
Old 07-19-2023, 09:11 PM #2
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Toyota dealership in Greenville, SC states $150-$300 per axle. That’s parts and labor. ~1 hr labor per axle ($80-$100) and ~$100-$200 in parts per axle.
You really just have to call around and ask for quotes. A simple job like this should be rough quote-able over the phone. Automotive Labor ranges anywhere from ~$60-$120 per hour depending on if you are in the middle of nowhere Louisiana or Metropolitan California. Also, many places won’t resurface your rotors these days…
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 07-20-2023, 06:01 AM #3
Thank you. The dealers here will resurface using an on the car lathe/. It is very accurate in terms of run out. But the cost they charge for it offers little advantage over simply changing the rotors.
Old 07-20-2023, 07:30 AM #4
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Last I was hearing about other toyotas(Sienna/camry etc), at the dealer 800 if they resurface, 1200 if they change rotors. You can probably get another shop to do pads and resurface rotors somewhere like firestone between 400-600
If you can DIY I would estimate <300 in parts and 2-3 hours of time to change pads and rotors.
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 08-10-2023, 08:17 PM #5
cumminsdieselfreak's Avatar
cumminsdieselfreak cumminsdieselfreak is offline
cumminsdieselfreak is on a distinguished road
Most dealers will be $1k-$1500 for new pads, fluid, rotors. You can do it yourself for less than $500 with Toyota parts. Just always remember to reset your caliper pistons and clean / grease your caliper slide pins (use grease designed for such). I use toyotapartsdeal.com for OEM parts, amsoil for fluids, and AGS Sil-Glyde for slide pins.
Sent from my Pixel 7a using Tapatalk
2022 4Runner ORP: Elka 2.5 DC, SPC UCA, 285 Cooper Rugged Trek
cumminsdieselfreak is offline   Reply With QuoteReply With Quote
Old 08-11-2023, 11:07 AM #6
rageandlove's Avatar
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
I literally just dropped my 4Runner off to have all 4 brakes done. ~$800 + tax. I'm in the Puget Sound area. Nothing is cheap here.
rageandlove is offline   Reply With QuoteReply With Quote
Old 08-11-2023, 03:33 PM #7
Fareastplaza Fareastplaza is offline
Fareastplaza is on a distinguished road
To DIY rotor, I am always fearing about removing it. In most case, rotor can be "welded" by rust.
Fareastplaza is offline   Reply With QuoteReply With Quote
Old 08-11-2023, 07:49 PM #8
I had the job done at a local shop that does good work. Work breakdown:
Resurface all four rotors;
Remove rear brake rotors and clean up the parking brake (nice and tight now);
New Toyota pads; and
Brake fluid flush.
$925 with tax.
Dealer was about $1100 without fluid flush.
Shop did a nice job. Brakes feel like they did when new in terms of pedal travel and stopping effectiveness.
I am in the MD suburbs of DC.
CNN reported today the average family is spending $700 per month more for the same basic spread of good and services as compared to two years ago. So in our house we are watching everything closely. Hope this helps others.
Old 08-12-2023, 10:47 AM #9
scottley scottley is offline
scottley is on a distinguished road
I just upgraded mine to the powerstop extremes. New pads and rotors were $500
10-23 4Runner Power Stop Z36 Extreme Truck & Tow Brake Kit
I'm by no means good at anything mechanical, but a brake job is a pretty simple operation. If your rotors are "rust welded" on, but you're swapping them out, just tap them real good with a hammer as you rotate them and they'll come off easy. Don't bend up your front heat shields pulling on them. Go to harbor freight and buy wire wheels and polish your hubs before you put your new rotors on. Have a second person to help with the flush (just get two quarts of brake fluid and run that all through). Took me a few hours to do... if you get these powerstops, the brake in (pun intended) is important, so follow the directions. Don't put your stinky, scorched brakes back in the garage after you do the brake in.
I'm kinda disappointed with myself for not buying the shiny red calipers they offer, but I thought it was a bit... extra... they would have looked real nice, though.
2016 T4R Four wheel brake job cost-img_20230805_193206-jpg
scottley is offline   Reply With QuoteReply With Quote
Old 08-20-2023, 02:52 PM #10
Was that including new rotors and brake fluid?
Old 08-20-2023, 03:17 PM #11
Jon S Jon S is offline
Jon S is on a distinguished road
I put power stop rotors on last time and didn’t get much out of them, they wore faster than the Oem, so I went back to solid rotors , most shops out here won’t turn them so replace is what I’ve done, a good hammer and turning them as you bang will get em off. Or you can use the threaded hole and press them off, never done that, but bet it’s pretty easy.
Jon S is offline   Reply With QuoteReply With Quote
Old 08-21-2023, 03:25 PM #12
SoCalRunner's Avatar
SoCalRunner SoCalRunner is offline
SoCalRunner is on a distinguished road
$800 in Austin
I picked up the Akebono full brake kit (Front&Rear) off Amazon for $420 and paid $400 at a local shop for installation.
2016 T4R TEP | Maxliner floor mat | KO2 285/70/17/C | Precision Interior LEDs | Ceramic window tint | AVS Aeroskin deflector | Rhino Rack Pioneer Platform | SunSeeker Awning | Fox 2.0 front/rear no res | Icon 52700 | VTX Wheels | Side exhaust | Xenon Depot HID Low Beams & LED fogs
Round Rock, Texas
SoCalRunner is offline   Reply With QuoteReply With Quote
brake , cost , job , pads , wheel
2016 TEP wheels - dealer cost? jon55nj Engines / Suspension / Wheels / Tires / Audio / Accessories 1 08-19-2016 01:30 AM
cost of brake job beerstash 3rd gen T4Rs 16 07-29-2011 04:51 PM
SR5 wheel cost jmbaker3 5th gen T4Rs 2 02-26-2011 11:18 PM
BRAKE Repair Cost? 4dailyRunner 4th Gen T4Rs 8 03-19-2008 01:11 PM
Brake Job: Level of Difficulty/cost? fluid15 3rd gen T4Rs 8 01-31-2005 01:31 PM
