Hello,
I've had my SC setup for a few years now, no major issues, only belt and pulley replacements. I have a lot of shtuff in my engine bay (hence the custom SC coolant res location) and noticed the other day that the SC coolant hose routing is starting to wear a bit where it rubs on the other hose and my wiring loom. I reached out to Magnuson and they said I could swap those hoses no problem, I will probably do this BUT I wanted to see if anyone has installed a 90 degree heater hose ending like this one and IF THIS IS THE CORRECT SIZE.
Heater Hose End Fitting - 90 Deg with 1/2" NPT and 3/4" Barb - Edelbrock, LLC.
Pretty sure it's a 3/4 barb but not sure what thread it is into the SC, NPT or? I guess I could take one off but trying to avoid that mess. The 90 degree fitting route would allow even more room for my wire loom, and yes my wire loom needs to be cleaned up again ;)
See where my hoses cross(top of pic, just right of center on supercharger)? I can swap them but wondering if anyone has installed a 90 degree there instead of the 90 degree hoses.
Engine bay
