Old 07-27-2023, 05:53 PM #1
Jkr4runner Jkr4runner is offline
Jkr4runner is on a distinguished road
Need Help Reading Spark Plug
My 2010 limited has 105k miles. I just did the 2nd plug change. One plug on the left bank looks different than the others. The 2 pics are the same plug from 2 sides. One side has a tan color., the other side looks like the rest of the other plugs. I could use some feedback on what could be going on in that cylinder.
I did find oil inside one plug hole on the right bank that will require valve cover removal to replace plug seals
Need Help Reading Spark Plug-20230727_161121-jpg  Need Help Reading Spark Plug-20230727_161134-jpg
Jkr4runner is offline   Reply With QuoteReply With Quote
Old 07-27-2023, 11:31 PM #2
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Both plugs looks normal to me. The tanned plug shows signs of being more worn. The tanned color is normal for a normally worn plug. The other plug almost looks much newer as it’s less tanned and slightly less wear on the electrode.
Otherwise no signs of wet/dry fouling, erosion, deposits, overheating or other “bad” conditions.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 07-27-2023, 11:37 PM #3
I need to repeat: the 2 pic's are of the same plug taken from each side. It's odd to me that one side has the tan color and the other side does not.
Old 07-27-2023, 11:45 PM #4
No, I read that in your original post. I’m standing with the tanning color being a normal but worn plug condition. As I said, it almost appears as if the bottom plug is newer. So, I agree it’s strange they are so drastically different.
My main point is neither plug condition in an isolated analysis is abnormal. No obvious signs of wet/dry oil/fuell fouling, erosion, overheating, melting, deposits (from coolant) etc..
If you don’t have any other symptoms like coolant or oil loss and so on, I wouldn’t be concerned with the result. It could well be that the bank with the more tanned plug is the hottest running cylinder due to the coolant path.
Plugs often come in packs of 4. Could it be one pack was actually counterfeit (2 of the 6 from previous change)? This is a documented issue.
Those are my visual observations. Did you measure the gaps?
Old 07-27-2023, 11:46 PM #5
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light
1000MPH's Avatar
Which driver’s side spark plug was this #6? Probably just need an Italian tune up.
1000MPH is offline   Reply With QuoteReply With Quote
Old 07-31-2023, 10:08 PM #6
Plug gap was similar on all the plugs - low .040's
Old 07-31-2023, 10:09 PM #7
Back cylinder left bank
bank , plug , plugs , replace , side
spark plug rounded, remove spark plug tubes? Danger Mouse 3rd gen T4Rs 0 05-02-2021 03:43 PM
Spark Plug cyl.3, this ok? UrbanRunnerNY 4th Gen T4Rs 8 06-08-2019 09:16 AM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
spark plug gap muddybamayota88 Maintenance/Detailing 0 08-30-2005 10:02 AM
Reading Spark Plugs Cincy4Runna Maintenance/Detailing 4 10-14-2004 02:24 AM
