Old 07-31-2023, 05:23 PM #1
JLRunner's Avatar
JLRunner JLRunner is offline
JLRunner is on a distinguished road
JLRunner's Avatar
Steering wheel wobble when turning.
Hello yall, I am stuck. I am getting a pretty aggressive steering wheel wobble when turning to the left @25mph or greater.
When the weight of the truck shifts to the right side(turning left) the steering wheel wobbles.
It also wobbles occasionally when braking. Rotors seem fine.
I have ruled out bad UCA bushings. Just changed them. Recently replaced lower control arm.
Any ideas? Truck is a 2011 2wd. 296k miles. UCAs changed. Ball joints changed. Shocks and springs upgraded. Sway bar links changed.
Most other suspension components are original. Wheel bearings original.
Thank you in advanced!
The Zombie Crusher
*JLRunner*
JLRunner is offline   Reply With QuoteReply With Quote
Old 07-31-2023, 08:23 PM #2
Jeremy556's Avatar
Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold Jeremy556 is a splendid one to behold
Jeremy556's Avatar
Lug nuts tight? (I'm sure you covered this, but just to check) Wheel lug holes wallowed out? Using correct type of lugnuts?
Grab the outer tie rod and see if there's any play in the ball joint in the inner tie rod end.
All bolts tightened to spec, especially LCA cam bolts? Has alignment cams moved (paint mark them)?
Old 08-01-2023, 11:16 AM #3
JLRunner's Avatar
JLRunner's Avatar
I will check all of this and report back, Thank you!
The Zombie Crusher
*JLRunner*
changed , original , steering , wheel , wobbles
Wheel wobble and steering off mendozer 3rd gen T4Rs 0 04-04-2016 03:00 PM
Fix for steering wheel wobble Ron4RNevada 5th gen T4Rs 5 10-25-2015 12:16 AM
Steering Wheel Wobble Deadly_Scionide 5th gen T4Rs 13 05-18-2012 03:27 PM
steering wheel wobble Cox 4th Gen T4Rs 7 05-09-2011 01:29 PM
Steering Wheel Wobble adamg32 3rd gen T4Rs 19 05-01-2010 12:23 PM
